Question about Ricoh Office Equipment & Supplies
Ricoh aficio mp 3350 finisher connecting & setup
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
  • 86 Answers
SOURCE: How to enter the maintance mode on a Ricoh MP 3350
If you want to enter in Service program mode please,
press Clear (yellow) button, 1 0 7, and press and hold Stop (orange) button for 3 seconds.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
  • 126 Answers
SOURCE: where is waste toner bottle
waste toner bottle is just beside paper tray 1. its the left side small cover. open the front cover and open the screw from top and open the cover in front and pull the bottle out. if its hard then email me on ronils_singh@yahoo.com.au. i am a Ricoh tech. i will help you out.
Posted on Oct 01, 2010
  • 23 Answers
SOURCE: how do i factory reset a ricoh aficio mp 2000?
what is the setings u want to reset ?
Posted on Feb 03, 2011
HELP ME RESET ERROR SC829 IN MY MACHINE RICOH AFICIO MP 3350
Code: SC829 Code SC829 Description Self-diagnostic error 9: Optional RAM Causes • Change the controller board or the optional RAM DIMM Sounds like an engineer is needed!
Dec 08, 2015 | Ricoh Aficio MP3350
Out of focus
Out of focus - Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher
Jan 29, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
When i copy using my ricoh aficio 3350 the machine cut the image in half, please help
Have you checked that you are 'telling' the copier to use the correct size of paper? You need to tell it that you are using eg an A5 image sheet and an A4 output sheet. The normal default is A4 for both.
Jan 07, 2014 | Ricoh Aficio MP3350
I want to relocate my Ricoh Aficio MP 3300
disconnect the finisher reset it and then it will be a monster roll
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
Ricoh MP 3351 shows messege SC798 , problems with finisher
Three possible cause:
- Poor connection between the finisher and mainframe.
- Finisher harness damaged or defective.
- Finisher unit defective.
For number 1 you can check the connection to make sure the connection is proper.
For number two and three, I am afraid you have to buy a new replacement unit.
Nov 09, 2013 | Ricoh Aficio MP3351
I would like to install ricoh aficio MP 2000 Le printer driver form the net.
how to install ricoh mp 2000le printer driver for windows 7
Jun 19, 2010 | Computers & Internet
Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Dec 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Reprint Last FAX on RICOH Aficio MP 3350
Once the fax was received and printed you can't do nothing.
It is not stored in the machine.
Please call the sender to send you the fax again.
Dec 30, 2008 | Ricoh FAX2210L Plain Paper Laser
285 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
