Question about Optoma Office Equipment & Supplies
Optoma hd67 flashing red light
Recently replaced bulb but has worked fine the last few days
SOURCE: flasing red light
power light green the lamp light flashes green for awhile then goes red. Replaced the bulb same problem.
I unplugged it then held the power button on and plugged the power cord back in. it started working correctly, and shuts off and on ok now.
Posted on Jul 17, 2008
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
SOURCE: optoma hd70 starts flashing colors
I removed the front cover and top panel, Using the Radio Shack dust removing spray, removed all dust from interior including circuit boards, color wheel ect, now it,s operating like a new projector.
Posted on Jan 04, 2010
  • 23 Answers
SOURCE: I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
Posted on Jan 21, 2010
SOURCE: Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Posted on Feb 06, 2011
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Optoma 25hd air filter issues
Hi Cathy,
The replacement of the filter is something that needs to be done at a service center by a trained technician. If you are interested, feel free to send us a message: Projector Repair Bulb Replacement
Jan 16, 2014 | Optoma HD25-LV - HD 1080p 3D Home Theater...
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Jan 31, 2010 | Optoma HD65 DLP Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma HD65 bulb only 108 hrs old having difficulty starting up
Use the warranty! since you anly had it for 8 weeks, and the waaranty last for one year, go back with it and get it repaired or get a new bulb. A buld last at least 2500 hours, in eco mode it last for over 3000 hours.
Good luck to you
Dec 17, 2008 | Optoma H30 Multimedia Projector
Projector will not turn on no fan no light
Hi!
Here is a link to the "Troubleshooting" part of the manual to Optoma H56 Projector. Hope it will help!
Troubleshooting Optoma 56 User Manual Page 27 of 32
Jan 04, 2018 | Optoma H56 Multimedia Projector
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Lamp light on picture off
You might try unplugging the set for maybe 20 mins. to see if that might help in resetting the internals. Good luck!
Mar 25, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
136 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
