Question about Minolta Di251 All-In-One Printer
ON A Di251F MESSAGE REPLACE IMAGING UNIT - Minolta Di251 All-In-One Printer
  • Minolta Master
  • 6,161 Answers
Then you need to get a new image unit when you open the right side cover the device with the two handles on it pull out and replace it. Try the web site below, that is a old machine if you can find the image unit. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 07, 2015
2 Suggested Answers
SOURCE: Missing Imaging Unit
When I had this problem the solution was a tiny piece of paper which was jammed in the machine.
When the jam was cleared the message went away.
Hope this helps
Posted on Jan 08, 2008
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Lexmark c 925 defective black imaging unit
You will need to replace it. If it was new, contact Lexmark regarding warranty of supplies.
Sep 24, 2014 | Lexmark C925, X925 Black Imaging Unit
How I can reset counter imaging unit bizhub c450?
u cant reset those , u have to change the counter chips .These are available in market
Apr 19, 2012 | Konica Minolta Office Equipment & Supplies
Re: Samsung Printer CLX3175FN -- receiving message "Replace imaging unit soon." I've read other expert replies but am still missing some information. Can I replace the unit myself? How do I do...
Nancy, Your imaging unit has a limited lifecycle. Documentation states that it can make 24,000 B&W pages and 6,000 color. The message is telling you that you are getting close to that limit. Eventually you printer will stop printing, and your messahe will state "Replace imaging unit". This can be done by you. It is very easy to do. The imaging unit is fairly expensive: around $150 or more depending on the merchant and shipping charges.
Drew
Feb 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLP 510 Imaging Unit
The Imaging unit needs to be replaced when the drum fills up with waste toner. That's what triggers the message.
Feb 02, 2009 | Samsung CLP-510 Laser Printer
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 asking for Imaging Unit
There is a spring on the waste section of the imaging unit that often pops off. When that happens it will not clear the replace imaging unit message. There is also a software patch on Xerox.com. Takes some searching to find.
Aug 11, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 Error U20
1. Contaminated or damaged Imaging unit contacts. - Remove and clean the contacts and inspect for damage.
TROUBLESHOOTING TIPS AND HINTS:
Imaging Unit Failure message occurs because the printer cannot detect imaging unit motion, up-and-down. The Transfer Belt drives this motion, and the Drum Contact Assembly detects it. 1. Swap the Imaging Unit Cotact blocks between two imaging unit positions. If the problem follows the Contact block, it should be replaced. 2. Open the Top Cover and defete the top cover interlock switch. The color imaging units should raise in succession, cyan, magenta, then yellow, and then all lower at once. If one or more imaging units do not raise smoothly or drop prematurely then replace the Transfer Belt assembly.
Apr 29, 2008 | Office Equipment & Supplies
Error message "engine firmware" code 72
Most likley the problem is a faulty Imaging unit. The chip on the unit has failed. You can try reseating the Imaging Unit and if that doesn't work replace it.
Here are the other listed causes.
Cause:
Corrupted NVRAM Possible Causes are Imaging Unit, Fuser, EEprom Board or PE/MCU Board
Feb 12, 2008 | Xerox Phaser 6200N Laser Printer
Minolta Di251 All-In-One Printer Logo
21 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
