Question about Sewing Machines
Where can I send my Euro-Pro serger to be repaired? I want to send it to Euro-Pro.
My serger is a 3/4 thread Euro-Pro. It has a broken spool holder and the upper thread tension knob is missing. I need it to be serviced. What is Euro-Pro's service address? I know I probably need an authorization number to send it in. Thank you, Carol
  • Sewing Machines Master
  • 7,365 Answers
  • Visit the Euro-Pro website at euro-pro.com.
  • Click the link on the right-hand side of the page below the text box, which reads "Customer Service: Click Here." This will direct you to a contact page.
  • call the number listed at the bottom of the text box for placing an order, 800-798-7395. Because no direct number is given for customer service, requests to contact a representative are fielded through this number
  • Posted on Jan 17, 2013
    forgot
    • 17 Answers
    SOURCE: baby lock denim pro
    try putting some bee's wax around your spool
    Posted on Dec 09, 2007
    bargainbox
    • 1388 Answers
    SOURCE: Euro pro serger
    There is a threading chart here
    Bargainbox
    Posted on Jan 27, 2008
    bargainbox
    • 1388 Answers
    SOURCE: Euro pro serger model 101-548
    3 thread overlocking (serging) is no different t 4 thread, except you remove one or other of the needle threads.
    The stitch width is then controlled by two variables,
    the manual width dial selector, and
    your choice of either the right or left needle
    Suggest yo play with width selector on a scrap of your project fabric to achieve the look you are after.
    Posted on Feb 17, 2008
    Michaelle
    • 65 Answers
    SOURCE: need manual
    Here's a start.. its the threading diagram
    sewusa.com has manuals for sale (sorry some older machine manuals aren't easily found for free)
    http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Euro_Pro_Sewing_Machine_Threading/euro_pro_534_dx_threading_diagra.htm
    I hope this was of some help.
    Posted on Jan 27, 2009
    danforddan1
    • 192 Answers
    SOURCE: I need instructions to Thread a White Super Lock 534 Serger
    I hope this helps. there a lot of other vidios you can try as well. DFD
    Posted on Apr 22, 2009
    My needle holder in my Euro-pro ep550 will not tighten to hold the needle in the machine. how ill i buy another needle holder to fit my machine
    if you take the serger to a sewing machine shop and show them the problem, they can check to see if the needle holder needs to be replaced or just some new screws
    Sep 06, 2014 | Euro-Pro Sewing Machines
    Does anyone have a suggestion? I have threaded the machine correctly but I cannot get the machine to sew.
    You have a nice serger, so let's start with some basics:
    Is your serger cleaned?
    Go back to the instruction book and set the entire machine to the factory settings. For example, set all the dials to tension 4. Use quality thread which is made for your spool holder. Usually cones of thread work best. Use an appropriate fabric, not sheer, not very heavy drapery fabric. Make absolutely sure it's threaded properly. Finally, make sure all the threads are under the presser foot.....then start serging. If the serger still won't serge without tangling, it might be good to have it serviced. I find that buying a new serger is more useful than having a worn out one serviced. Good luck!
    May 05, 2014 | Brother 925D Serger
    SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
    Serger thread breaks
    1. Is the serger threaded correctly?
    2. Is the needles inserted correctly?
    3. Is one of the needles bent or damaged?
    4. Is the tension adjusted too tightly?
    5. Is the tension adjusted to accommodate thickness of thread being used?
    6. Are you using inferior quality thread?
    7. Is the thread feeding off the cone/spool freely?
    8. Is the needle size correct for the type of fabric being used?
    9. Are the needles being used the correct one for the serger?
    10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
    Aug 21, 2013 | Singer 14SH654
    Thread tension problem
    Got a serger huh? First put 3 different colors on the spool holders. Then play with tensions so you understand which thread does what.
    It's trial and error. Good luck.
    Oct 25, 2012 | Sewing Machines
    The thread keeps tightening and loosening causing the stitching to be off.
    This happened to me once on my machine...Pfaff. There was a teeny weeny bit of thread caught in the tension disks. I slid a piece of paper between the discs and eventually got it out. Also....if you sew with cones the thread tension often goes off because cones are not meant to be used on the spool holder. Buy a special device for holding cones of thread....it sorta looks like those verticle paper towel holders. (a disk with a stick poking up from it) This will solve your tension problems and prevent needles from breaking all the time. If neither of these ideas help......maybe your machine needs servicing. Give these a try first.....might save yourself a big repair bill. If you can't find the cone holder........wind off thread from your spool onto a bobbin and use that as your upper thread.
    Dec 21, 2010 | Euro-Pro 9125 Computerized Sewing Machine
    I have never used a serger before and a friend is letting me use hers. There is string on the machine, but how do I put the colors I want on and get it to the needle? The machine is a Baby Lock BL3-417. ...
    here's a tip I learned for sewing machine or serger
    do one thread cone at a time-the cone or spool that's on the serger--cut the thread close to the cone-then remove the cone from the serger ,,don't remove the thread that you just cut from the serger,,now put your thread on the spindle & tie your thread to the thread that you just cut (make sure it's a small knot) now the thread that's in the needle pull until the thread that in the needle is your & then cut off the other thread & make sure to cut of the knot part & leave a thread tail of 4 to 6 inches
    do each spindle this way
    Dec 09, 2010 | Baby Lock Sewing Machines
    How to thread euro pro serger. threads aren'y interlocking
    If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
    Turn off the power.
    Raise the thread antenna to it's highest position.
    Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
    Turn the handwheel so the loopers are at their highest position.
    Begin threading from the right to the left - lower looper is usually the first to be threaded.
    After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
    Mar 23, 2010 | Euro-Pro Sewing Machines
    Euro pro serger
    Bargainbox
    Jan 22, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
    Threading machine
    The machine is relatively simple to thread. This is what I do and I've had no threading problems. 1. Put thread spool on the spool pin and put spool guard over spool pin to hold spool onto pin. 2. Take thread and put it under the bent tab by the circle tensioner. bring the thread around the right side of the circle tensioner and bring around the front of the circle tensioner thing back to the top hook on the far left side of the machine. 3. Take the thread around the backside of the top hook think until it threads through the flat piece on the left side of it. 4. Bring the thread down through the first (right side) channel and under the plastic piece to the second (left side) channel. 5. Bring the thread up the second channel and around the moving thread holder and past it's flat metal piece to hold it. 6. Tuck the thread around the small wire thread holder below the needle screw. This may take a few passes to catch it. 7. Thread the needle from the front and run the thread between the teeth of the presser foot. 8. Put a bobbin in the bobbin case so that the thread pulls off the bobbin from the left side of the bobbin if you look at it from above. 9. There is a small channel in the bobbin case that is covered by the bobbin tension flat piece. Pull the bobbin thread through this channel and into the empty space where the needle thread will catch. 10. Place the bobbin case into the machine with the little set bobbin arm pointed to the sky so that it fits into the machine without wiggling to the right or the left. 11. Turn the, uhhh brain fart, the hand wheel until the needle comes back up with the bobbin thread hooked over the needle thread. Take a narrow thing, like scissors or a seam ripper and pull both threads until the bobbin thread comes up. Now your machine is threaded. Use these directions with the pictures in the book to get this machine threaded.
    Dec 11, 2006 | Euro-Pro Fast and Easy 420 Mechanical...
    Sewing Machines Logo
    89 people viewed this question
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Chris Wetmore
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
