Question about Nvidia GeForce 9800 GTX,, PCI Express Video Card
No signal i have recently build my own computer and connected everything up to find that i have no signal from my graphics card to my monitor. the graphics card is a Galaxy 9800 GT and seems to all connected but i dont get any signal. i have tried mulitple monitors and i still dont get a signal, i also tried unplugging unneeded power users such as fans to see if it was a power issue, no luck :( ... tried unplugging and reconnecting everything but still didnt work, hoping some1 can help. cheers
  • povnish Feb 01, 2009
    thanks 4 your help. found out the graphics card was faulty.... needed 2 be held in to recieve a signal, got a replacement 1 which worked fine. thanks 4 ur quick and very helpfull information
    President:
  • 1,179 Answers
Do you have both the 24 pin plug & the 4 or 8 pin plug, depending on board, plugged into the proper places? The 4 pin plug is what powers the pci-e x16 slot. On some newer boards it will be an 8 pin plug rather than a 4. It should be clearly marked on the mb in small print. Hope this helps.
Posted on Jan 25, 2009
My monitor displays 'no signal' on a blue screen then goes dark
check the connection between the computer and the monitor
plug into onboard graphic port or graphic card check power connection on graphic card if needed.if your techie reseat graphic card with computer unplugged
Feb 18, 2016 | Computers & Internet
I have a new asus VS197D then when i turn on it said NO VGA DISPLAY
if there is a graphics card in your pc than you should connect VGA cable to graphics card. may be you connected onboard graphics. just check hope that it will help you
Feb 15, 2014 | ASUS Computers & Internet
Monitor states No signal. this is a new computer, just today
Make sure you are connecting the monitor signal lead to the correct signal output on the rear of the machine. Some desktops have extra video out connectors when they have a graphics card fitted. If yours has a graphics card the display connector will be away from the back USB ,audio and keyboard ports and near to some silver pop out panels near the bottom of the tower.
Apr 20, 2013 | Acer Aspire m5640 PC Desktop
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
When i turn on my computer the monitor remains in stand by with the screen black and it says There is no signal coming from your computer.
Hi the first thing to do is switch it all off at the mains, then unplug everything from the back of your computer then plug everything back in doing this will remove any static build up that could be causing problems with your video card.
then check the cables at the monitor end if they dont come out of the monitor give them a wiggle just to make sure they are not loose then plug everything back in and switch it all on.
if after doing the above you still have no picture then the problem is going to be with the video or graphics card in your computer, if this is the case then the chances are it has over heated if this is the case then replacing the graphics card should solve your problem, if how ever your computer dont have a graphics card and its just plugged into the mother board then this itself may need replacing.
let me know what happens after you have unplugged everything ok
plz rate this solution as i have loads of posts that are unrated taking up my whole page, thanks
Aug 27, 2010 | Dell Inspiron 530s Desktop Computer...
I have had the monitor for over a year .computer stoped working added new machine.no input signal using 5450 512 mb graphic card computer starts to boot monitor is on dispaly no input signal message or...
check the connections on the backside of ur computer.. are the connections inserted properly.. if they are still try to remove and reinsert the connections properly and tighten up the screws properly.. 2) there is a possibility that the graphic card is not seated properly.. so remove the graphic card and reinsert it once again to check that.. 3) still no go then .. remove the graphic card and try to boot computer with onboard graphics.. if the computer boots up there can be a problem with the graphic card.. check compatibility of the graphic card with ur computer.. let me know if this resolves ur issue regards, guru
May 05, 2010 | HP w1907 LCD Monitor
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Nvidia geforce9400gt monitor problem
Usually the problem with windows 7. if you have 2cables connecting from youre monitor to the graphics card, unplug one of them, it worked for another guy
Mar 24, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
No signal on monitor
You probably have 2 monitor connections. you have a standard one, and one that is through a graphics card at the bottom of your tower. Check for that second connection and switch the plug.. that should solve it.
Jan 02, 2009 | Gateway FPD1975W 19" LCD Monitor
Building new computer - nothing on the monitor.
whats your graphics card model and what kind of power supply you have?
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
Nvidia GeForce 9800 GTX,,  PCI Express Video Card Logo
222 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
