Engel Freezer 22 Qt. Fridge/Freezer Logo
Matt Pearce Posted on Jul 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge freezer not chilling!
I have a 2 year old fridge freezer that doesnt get cold.. the compressor runs and I can hear some kind of liquid flowing throught the back cooling radiator but neither the fridge or the freeezer gets cold.. I cant test the thermostat because it wont switch the compressor off until it reached a minimum temp. (I wondered if the thermostat does something else?) I had thought that somehow we had released the gas, by overfilling the freezer compartment with food and somehow damaging the soldered links in the pipework, but all seems ok and I have tried applying washing up liquid to each visible soldered joint (with the commpressor running) to see if any bubbles appear but all seems quite sealed.. Id be grateful for any advice , many thanks, Matt. I guess the unit might make a good tool storage chest but Id rather have the fridge working..!!
  • 1 more comment
  • Matt Pearce Jul 13, 2007
    Hi , I cant seem to find Noggin's posted solution..
    please advise.
  • Matt Pearce Jul 14, 2007
    cant find noggins solution even though I have looked through al;l of his
    profile..
    please advise.. Kilminster
  • Matt Pearce Jul 16, 2007
    Many thanks for this , certainly, it does seem that we have lost refrigerant, but the unit has always been placed in a cool kitchen,
    I was just hopint that there might be something else in the control system that I had not considered..
    perhaps I should cut my loses and simply buy another..
    Indesit are not the most expensive brand around!
    many thanks.
Anonymous
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on Jul 19, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
172185
Points
274
Sounds like there is a leak somewhere in your system. One way you can check yourself is to run your fingers over every solder joint you can find and if you feel any oil at a joint or if I think you said there are coils in the freezr check them too and if you find oil you found a leak. There also could be a small pin hole in one of the coils and you may not find any oil. Most times its a bad joint and it will be wet. other then that either call a repair man or as you said convert it to a tool box. Good luck
Anonymous
Level 2:
Novelist:
  • Expert 114 Answers
  • Posted on Jul 15, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
114
Questions
0
Helped
80865
Points
200
NEVER TEST FOR LEAKS USING A VACUUM PUMP !!!!! IF YOU HAVE A LEAK IT WILL PULL AIR AND MOISTUREINTO YOUR SYSTEM. REAL REFRIG. REPAITMEN KNOW THIS AND CARRY NITROGEN AND LEAK DETECTORS TO FIND LEAKS. THE REFRIGERANT LEVEL CAN EASILY BE CHECKED BY TAKING THE TEMP AT THE CONDENSER COIL OUTSIDE AT THE TUBBING ON THE CONDENSER. THERE SHOULD BE A 20-30 HIGHER DEGREE DIFFERENCE THAN THE AMBIENT AIR TEMP.(INSIDE OR OUTSIDE TEMP.) IT SHGOULD BE AT LEAST 110 DEGREES. THESE COOLERS ARE NOT MADE FOR HEAVY LOADS. THEY ARE DESIGNED TO KEEP COLD PRODUCTS COLD. TRYING TO COOL WARM PRODUCTS IS A OVERNIGHT PROCEEDURE AND A WASTE OF TIME AND MONEY. HEARING REFRIGERANT GURGLE IN THE SYSTEN AFTER AN HOUR OF RUNNING INDICATES A LOW CHARGE. MOST OF THE TIME A SMALL SPOT OF ICE WILL ACCUMULATE ON THE INSIDE OF THE FREEZER WHEN IT IS LOW. IF A LEAK WAS REPAIRED AND A VACUUM PUMP WAS NOT USED TO REMOVE AIR AND MOISTURE FROM THE TUBING, COILS, AND COMPRESSORM TO 29" VACCUUM YOUR DEVICE WILL NOT WORK PROPERLY. YOU CANNOT COMPRESS LIQUID OR AIR IN A REFRIGERATION SYSTEM !!!! IT IS CALLED A NON-CONDENSABLE. WHEN MIXED WITH DICLOROMONOFLOROETHANE OR ANY TYPE OF REFRIGERANT IT WILL TURN THE MOISTURE AND AIR INTO AN ACID. THE THERMOSTAT HAS NO OTHER USE BUT TO MAINTAIN TEMP (33-50) SOME HAVE AN "OFF POSITION. THESE A SMALL MACHINES TO DUMP- ALOT OF MONEY INTO IT... I WOULD CUT YOUR LOSSES ESPECIALLY IF SOMEONE ALREADY RIPPED YOU OFF.
Anonymous
Level 3:
  • Master 944 Answers
  • Posted on Jul 13, 2007
Anonymous
Master
Level 3:
Answers
944
Questions
Helped
786552
Points
2417
It sounds like you have a problem seal that has allowed the refrigeraqnt out - perhaps the unit got excessively hot (in the sun or similar), and due to the lower pressure in the system, the seal is no longer leaking. You need to get a fridge guy to vacuum test the system, and change the refrigerant if he thinks necessary - he can also check for leaks without the risk of sucking detergent into the system. You could do all this yourself with the right tools and refrigerant, but unfortunately it is now almost universally illegal to carry out these sort of repairs without being qualified and certified. Hope this helps :)
  • Anonymous Jul 13, 2007
    I'll post it again in case;
    It sounds like you have a problem seal that has allowed the refrigerant out - perhaps the unit got excessively hot at some point(in the sun or similar), and due to the lower pressure in the system, the seal is no longer leaking.
    Hope this helps :)
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
1helpful
Frigidaire refrigerator compressor overheated when I left the door opne.
the motor of the compressor may have tripped on overload protection. Allow it to cool down and then unplug the fridge then plug it back in and try to run it. It should run. Be advised that the condenser coils underneath need to be clean. You should have a strong person tilt the empty fridge while you vacuum and clean all the dust and lint off the coils. Be gentle as these coils are fragile and are easily damaged. Hope this helps.
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
Fridge 14 yrs old. Unplugged for 2 yrs - now won't cool.
with the unit being that old , the compressor probably whent out the oils inside probably froze up ,,,,, to replace a compressor you are better off replacing the unit it is a major repair
1helpful
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
2answers
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 • Freezers
4helpful
4answers
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 • Freezers
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
2answers
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Top Engel Freezers Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you an Engel Freezer Expert? Answer questions, earn points and help others
