Question about Packard Bell Computers & Internet
My PC when plugged in does not turn on but only powers the fan
I have plugged in my PC, and when i press the on button, only the fans switch on, when I remove the power cable the light on the main start up button flickers so it seems the power supply is knackered? Anyone know what could be wrong or if they have had a similar problem? Thanks Chris
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
Is there beeps coming from inside the tower case? Does the Hard Drive make a spinning sound after about 15 to 20 seconds? It could be a mother board issue, it could be a graphics card issue.
Posted on Jan 17, 2013
  • chris markwick Jan 18, 2013
    no beeping at all, all that happens is the fans turn on, i hear nothing else. My computer was working fine, this was 8 months ago, i bought a laptop and never really used my PC again, so it has not been turned on in 8 months.
PcExpert
  • 293 Answers
SOURCE: Power problem
NO POWER Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver. FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 20, 2007
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
alexgalapin
  • 148 Answers
SOURCE: My Dell Dimension 4600 PC won't power up. When you press the power button the power light shortly lights up and the fan fan of the power supply rotates for a short time and stays off.
  • you may need to replace the power supply and ask a local computer technician to replace it
Posted on Jun 02, 2009
  • 523 Answers
SOURCE: Press power button. Green light turns on, fan
there is power buttom on the keyboard makes it wake up. try it
Posted on Oct 03, 2009
Techie2core
  • 42 Answers
SOURCE: My emachine T1742 desktop will not turn on. When
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Posted on Dec 03, 2009
Emachine EL18252 G-52W won't start when pushing power button
Disconnect the desktop computer from the electrical power.
Plug it in, while looking at the computer, and listening for any noises (spinning fans, or lamps that light up) as soon as it is plugged in. Then, press the ON/OFF switch, and watch any lamps, and listen for any fans. If nothing, then the power-supply is the problem.
Aug 21, 2015 | Computers & Internet
Computer won't come on when pressing power button
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
When the computer on/off button is pressed , the CPU fan and tower exhaust fans start running, the blue light around the power button does not light and the boot up process goes no further. Fans continue...
A) When you hold a Power On button, (Switch actually), in for a count of 10 seconds, it turns the computer off.
(There is a Power On switch, located behind the plastic Power On button. Usually, the Power On switch snaps into the housing of the plastic Power On button.
Example of a typical ATX Power On switch,
http://www.directron.com/atxswitch.html
The Power On switch turns the Power Supply on.
Old computers had a metal rod, that when the Power On button was depressed, the button pushed against the metal rod, which in turn pressed against a power switch located inside the Power Supply.
The design after that, was a power switch located in the Front Panel. (Plastic front of the computer) A large cable, (Wire) ran from the switch to the Power Supply.
Now there is the Soft Power On feature. (PS_ON)
The Power On switch is a small Momentary Contact Switch. Pressing it closes a circuit. The Soft Power On circuit.
When a power supply is plugged into power, there is a constant 5 Volts (DC) present.
This is the 5 Volt Standby.
Closing the Soft Power On circuit, redirects the 5 Volt Standby power to a circuit within the Power Supply.
This in turn 'excites' the Power Supply, and turns the Power Supply on.
Sorry to be windy, but I wanted you to know how the Soft Power On feature works )
eMachines are a budget computer. As such they save the consumer money.
However in order to do this, the manufacturer will install low quality parts, in some areas of the computer.
One such part is the Power Supply.
1) ALL the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
(Had you stated the Model Number I could have told you)
Enough power to spin fans, but not enough to spin fans, AND turn the Processor on.
Do you have access to another computer that is unused, but has a Known to be good, Compatible power supply?
It could be used for a test unit.
Tell me the Series, and Model Number of your eMachines, and I'll tell you what Wattage it should have, and what power cables, for the Power Supply.
(Some examples of Series, and Model Numbers, T1090, E4264, W2925, and so on. The T, E, and W are a few examples of the Series letter.
The numbers following the Series letter, is the Model Number)
If you wish I can direct you in removing the Power Supply, and installing the test unit. (And/Or a new Power Supply)
Sep 12, 2010 | E-Machines eMachines Desktop PC
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Dec 03, 2009 | E-Machines eMachines Desktop PC
Won't come on, tried taking out battery and that
take the cd drive out and look to see if it has grounding out marks on the back and look inside the bay
May 22, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Computers & Internet Logo
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
