Protection, no sound - Audio Players & Recorders
    New Friend:
Wire for speaker touching together to graund
Posted on Jan 17, 2013
First problem ever--enjoying the unit when it has suddenly begun to stop producing sound and a flashing 'protect' message appears. The system is still running the CDs but no sound.
Your unit is in protect mode because some component or components failed. Could be overdriven output stages or something related.
Jun 09, 2018 | Televison & Video
Overload light on can't get any sound
here is your guide:
http://www.fixya.com/support/t13907270-sony_str_de925_stuck_in_protect_mode
Note : output transistors are embedded inside the Hybrid IC
on some models.
Aug 07, 2012 | Technics Audio Players & Recorders
How do I disconnect The protection from deletion key
While reviewing the protected picture, press cursor-down to bring up the Playback Mode Palette. Use cursor-left/right to select Protect (the key icon) and press the OK button. Press cursor-up to select "Single Image/Sound" and press OK. Use cursor-up/down to select "Unprotect". Press OK.
Full details are in the "Protecting images and Sound Files from Deletion (Protect)" section of the manual (page 170 in my copy). If you need a manual, you can download one at
http://www.pentaximaging.com/images/temp/63389987065168840454432X70%20Manual_English.pdf
May 10, 2011 | Pentax X70 Digital Camera
How do I go from "Protect: mode back to FM play on
The word protect will engage when you have output problem and will shut the audio off so no sound is available, however if the sound is working normally with protect visible then there is clearly processor issue, something I have never seen before. But it should be checked by a qualified tech.
Dec 29, 2010 | Sony LBT-LX50 CD Shelf System
Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
Jun 06, 2010 | Harman Kardon AVR 340 Receiver
No sound from zenith dvt412 stuck in bypass mode..how to override?
this is a protection circuit.
When bypass mode then it means that something in the power supply module has failed and the unit then goes into protection mode to protect the board components.
Your surround sound need service from a qualified tech. No other remedy.
Mar 24, 2010 | Zenith DVT412 System
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
Audiobahn A6601T amp. Protection light on. No Sound output.
Disconnect all speakers from the unit and then switch it on. If the protection light is still on then the output stage in the amplifier is blown.
May 12, 2009 | AudioBahn A6601T Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
47 people viewed this question
 Grubhead
Grubhead
