Question about RTO Mega Motion 3 Wheel Travel Pal Scooter
1. what are wire connections at base of seat for? not in manual?
The red wires have red connectors. 2. unable to complete charging; what gives?
What colour wire does what with Samsung in ear earphones
This is an educated guess.
You should have 4 rings around your 3.5mm connector. From the tip to the base of the connector....
#1 - left audio - Black
#2 - right audio - Red
#3 - Ground - bare copper
4# - Mic/volume - green/brown
The wires for the left and right channels (pins 1 and 2) and the ground, (pin 3) should run from the connector through the volume control, to each ear piece. The mic/volume wire should terminate at that control. although it could connect to more than one place within the control.
You may be able to open the volume control, gently, and see which wire stops there and which continue on through.
I hope this gives you enough information to complete your project.
Dennis
Apr 22, 2014 | SAMSUNG EHS64AVFWE Stereo 3.5mm White...
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Where are the driver's seat relays on a 2005 deville?
There isn't a separate "relay" for just the drivers seat. All the seats get power from one location so if the others are working you may be dealing with the controller/switch which is likely. If you can get to the plugs/connectors on the seat adjuster switch/module check any orange wires for power. All seats are connected to a 30 amp circuit breaker and am sure but am unable to get you a picture of the connectors right now but have them but know in the 05 devilles the orange wire is the power source. If I'm not mistaken there is a connector with only 2 wires (ornge & black) but don't quote me on this. If I am right, check the orange wire there. If there is power there you have power too but from there to the motor(s) and further tests need to be done to narrow down the problem. It could even have something to do with the memory seat controller. If you need further help you can reply here or email me directly at csautomotivecars@att.net with your information and I will be happy to help you with some tests to narrow it down. No there wouldn't be a charge for my help. Hope what little information I have given you at least helps some.
May 18, 2012 | 2005 Cadillac Deville
Hi, I have a 2001 Mazda Millenia S. The light for my heated seats come on, but there is no heat in either the driver's or passenger's seat. What could be the problem?
Mazdas are pretyy bad about the seat heating elements burning out. To verify that the problem is not the circuits to the elements, remove the 4 bolts holding the seat to the floor and tilt the seat back. Find the 2 pn connector for the heating element under the seat. (On the driver's side it will have a White and Red wire and a Yellow and Red wire. On the passenger side it will have a White and Red wire and a Green wire) Disconnect the connector. Using a standard 12 volt test light and a paper clip, use the paper clip to connect on end of the test light to the White and Red wire and probe the Yellow and Red (or the Green wire) with the test light probing end. With the ignition switch on and the seat switches turned on, the test lamp should light up. If it does, you need to replace the heating element in the seat. If it does not light up, post a comment to let me know, and I'll talk you through diagnosing the heater circuits.
Mar 25, 2011 | 2001 Mazda Millenia
My battery light and my brake light comes on at the same time. after that my car went completely dead. I replaced the alternator and the wire that connects to the alternator and I am still having the...
1. Check the voltage on the White/Red wire at the 2-pin connector on the alternator. Key on engine off there should be near zero volts and when the engine is running and the alternator is charging the voltage should the charging system voltage (13.8 - 14.2 volts). Voltage drop the alternator case to battery negative. Voltage drop the battery positive circuit to the Black/Red wire (Large wire on output post) and the Yellow/Black wire in the 2-pin connector (sensing voltage). Looking for 0.05 volts maximum.
2. Disconnect the 2-pin connector at the alternator when the engine is running and the alternator light is on. The light should go out. If not, then there is a circuit problem (shorted to ground).
Feb 17, 2010 | 1997 Nissan Maxima
Panasonic cordless phone KXTG2431 discharge too fast
Hi,i'm hamed from IRAN
I have a panasonic phone model:KX-TC1282JXB and it has a problem: Discharge very soon the battery and recharge hardly or phone can't recharge it !?
<< My dicovery solution worcking 100% >>
Steps:
1-remove battery from remote-handel.
2-create two wires.
3-the jumper of battery must have two wires(red & black).
4-contact you're created wires to jumper of battery.
5-be careful! now you must connect two wires to base of phone where the remote-handel settle there at below be exist two slots "phase+" and "null-".
note: when you connect correct,the green lamp must be shining.
Recommend: (near slot by base keyboard connect black wire) and (other slot connect red wire).
6-connected battery must be take between 45min - 75min.
note: the battery to be warm don't worry, just control to pass time.
7-then release base and battery form two wires.
8-connect the battery to remote-handel,you can see it has charged for minimum amount (one-unit)
9-finally connect remote-handel to the base for give full charge,it take between 8h - 12h.
you can ask me you're question(s) : hamedsbt@yahoo.com
bye :-)
Jan 24, 2009 | Panasonic KX-TG2431 Cordless Phone
PHILIPS HEADPHONES SBC hc 8440
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Jun 01, 2008 | Audio Players & Recorders
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
RTO Mega Motion 3 Wheel Travel Pal Scooter Logo
21 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
