Question about Elite Csw200 Ul Swing Gate Operator Gate Opener Csw 200
Gate wont open or close
After storm gate open a foot then try to closed
  • 116 Answers
SOURCE: Sliding gate will not close
Check track for obsticles, Does it slide smoothly or does it hand have way and get more difficult, Clean any sensors you can see with a clean rag. Let me know what you find.
Posted on Dec 11, 2008
SOURCE: Gate will not completely close.
Most likely your chain is not going to be your problem. When you pull the cover off of your SL 3000 there will be a little rectangle box on top. There is either one or 2 screws holding the lid down...loosen the screws and take the lid off. Inside there will be a long screw drive with 2 plastic nuts with teeth.At either end of the screw drive you will find a switch that one of the nuts should be resting on. (these are your limit switches that tell the motor when to stop) Run the gate open and closed...when you run it closed see if it is hitting one of the limit switches when it stops. (turn off the power) If so, hold back the plate keeping the nut in place and move the nut further away from the limit switch.(don't move it too far so that you don't slam the gate too hard into the catch post and hurt the post/gate/motor) Turn the power back on and run it again. Repete this untill the gate is stopping where you would like it too. e-mail me with any further questions tgutierrez13@gmail.com
Posted on Jan 10, 2009
  • 52 Answers
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
Posted on Jul 02, 2009
  • 366 Answers
SOURCE: my sl 3000 ul gate wont open unless I help it out
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Posted on Jan 24, 2010
  • 14 Answers
SOURCE: i have an elite robo swing r900 gate opener. gate
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
Posted on Mar 13, 2010
How to adjust open close limits on a 4 meter gate for a Germin motor
on the shaft that controls the arm or gear for the gate movement there will be 2 cams
open the gate and then loosen of one cam and adjust it off the micro switch until the gate is fully open
lightly tension the screw and then close the gate
repeat the adjusting on the second cam until the gate is fully closed
tension up the screw and then using the remote open the gate when it is fully open leave it or in it is not make small adjustment to get it open
press the remote to close the gate and again adjust to properly close the gate
May 02, 2018 | Cars & Trucks
Had error message "gate". After opening and closing my rear gate,(2010 Jeep Liberty), interior lights went on. Made it to work. Tried to start car after work and the battery was dead.
scan it.
the CEL lamp on running means. "SCAN ME.," now.
the gate warning means just that, gate in ALarm.
and needs to be repaired.
Apr 09, 2015 | 2010 Jeep Liberty
Gate opens by itself at any time and doesnt close,,, any help ?(new d5)
I need more information on your automatic gate opener. What brand opener is it? What brand of remotes are included? do you have a keypad outside the gate? Roughly, how old is the machine? Have you had any electrical storms recently prior to this issue starting?
Sep 12, 2013 | Building Materials
Myhouse gate
There is a switch in the housing that tells the controller if the gate is open or closed. The switch is bad or out of adjustment.
Aug 21, 2013 | Home Security
2012 liberty rear latch stuck
no answer but same problem. ever figure it out?
Feb 03, 2013 | Jeep Liberty Cars & Trucks
Toyota 4runner Lift Gate Won't Close/Open
Insert the key and turn the lock cylinder while lifting up on the lift gate. You have to get the gate open. Once open, The strike plate (where the locking mechanism hits) is bolted to the jamb. Loosen the bolts and slightly move it toward the rear of the vehicle. NOT TOO MUCH!
Tighten the bolts, and try it. Hope this helps.
Jan 30, 2018 | 1996 Toyota 4Runner
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
1992 Chevrolet Silverado 1500 tailgate wont latch
latches for this are on the sides. The are connected by the handle in the middle of the gate. Latches are either stuck open (dry or frozen open) or stuck closed and you are banging on them when trying to close and "latch" gate. Get a screwdriver and while pulling up on tailgate handle make sure latches(on gate) are open to engage "striker bolt". If they are spray them liberally with WD40 or silicone SPRAY. latch and open several times to let lubricant attack rusted area on mechanism.
If latches won't open they may be stuck closed and won't open because cable going from middle handle to that side or both sides is disconnected. Does tailgate have star shaped bolts on "inside-bed-when-closed" side? If so you will need to spray these with WD40 and let set then get a star torques bit and remove them to access middle handle actuator.
Apr 26, 2009 | 1992 Chevrolet C1500
Jan 08, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Csw200 Ul Swing Gate Operator Gate Opener Csw 200 Logo
35 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
