Question about Fujitsu ScanSnap Manager
Noise when scanning document
My ScanSnap S510 started making a clicking noise when it's scanning. Do you have advice on how to fix it?
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
PA03360-Y110
Pick shaft
PA03360-Y112
Pick Bearing ‘M’
PA03360-Y107
Clutch
PA03360-Y106
Clutch Spring
PA03360-Y105
Pick Gear
Regards,
Eric F.
Posted on Feb 06, 2009
Its the gear behind the gear thats attached to the big feed roller. Remove the feed roller and the axle its attached to. Behind the geared wheel connected on the left of the axle you will find a tooth missing. Its the drive gear for the feed roller.
Posted on Feb 06, 2011
  •  Richard Hein
    Richard Hein May 05, 2012
    How do you replace it?
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
I SCANNED A DOCUMENT. A WINDOW POPPED UP ON MY DESKTOP MONITOR WITH THE NOTICE "UNDEFINED ERROR OCCURRED (Oxffffdcf7). WHAT DOES THIS MEAN? AND... HOW DO WE CORRECT IT?
Please update to the latest version of the ScanSnap Manager. You can obtain the latest version from the following URL: Click HERE
Aug 17, 2011 | Fujitsu ScanSnap S510
After scan Scan Snap S510 fails to display the document and serial number in the Scan Snap organizer. How do I get this to display in the scan snap organizer again?
Here is how you fix it. Sell the scanner and make $200.
Put all your documents into an envelope and have us scan all your document for you!
Go to Shoeboxed.com and check out what we do and then call me, Justin, at our main number and I will set you up with a complimentary 150 free scans of all your receipts, business cards, and other documents all on the house!
Call 888-369-4269 and ask for me!
Jun 25, 2010 | Fujitsu ScanSnap S510
I can not scan to folder now, I am using scansnap s510m, please guide how to solve this problem. I am using macbookpro
Click and hold down the mouse button over the ScanSnap Manager Icon in the Dock menu and confirm that Quick Menu is checked.
load the document you want to scan
press the scan button
when scanning is complete the snapscan quick menu appears
place the curser on the scan2 folder
click it in the action list
a preview window appears
You can change the file name and the folder you want to put it in. You can also resize it here by dragging the lower right corner
here is the manual
http://www.fujitsu.ca/pdf/scanners/manual/operator/s510/S510M_Owner_P3PC-1942-01ENZ0.pdf
Dec 31, 2009 | Fujitsu ScanSnap Manager
How do i delete error pages after scaanning?
I changed the settings from duplex (double sided) scanning to simplex (single sided) scanning under the settings tab in the scansnap organiser. this was ok since i had all one-sided documents to scan. you would need to reverse this settings change anytime you have a double-sided document to scan.
Nov 18, 2009 | Fujitsu ScanSnap S510
After scanning the first document and saving the file the scanner will not scan another document. I have to close it and open it back up to scan another document.
your memeory does not allow to scan more than one documents and when you close and reopen it refresh the temp. memory in your system...try to clean all cach and and clean the system or close some of the background applications that is running.
Nov 07, 2009 | Fujitsu ScanSnap S510
Error when scanning over 6 pages
I thing you exceeded the data limit so cut the last 5 pages and paste to one new document now scan the new document then cut the new document and paste it to original document. that's it.
Jun 09, 2009 | Fujitsu ScanSnap S510
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
Computers & Internet Logo
2,310 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
