When I try to start the car it wont kick over or it does but stalls
SOURCE: 2005 chevy malibu won't start
You will need to Check the Fuel Pump and Relays, and also Change the Fuel Filter. There is a Fuse Relay Box under the Hood that has the Fuel Pump Relay in it.
SOURCE: my 2005 malibu sometimes stalls for no reason
If the check engine light has not come on you could still take it to an autoparts place and have them test your car. It is usually free. You may have a burned out indicator light. If your car has not set a error code there are several things to check. Low vacuum pressure caused by bad hoses, pcv valve, EGR diaphram, manifold gasket, or brake booster. Low idle rpm caused by above items or throttle position sensor, steering step-up switch or mechanical adjustment on throttle body. In extreme cases dirty air filter, water in gas, fuel pump pickup on low tank. Hope this helps.
SOURCE: 1990 c1500 350 5.7l TBI wont start sometimes. Fuel
If you pull the aircleaner off and watch the throttle body injectors they dont have anything coming out?
Double check the map sensor and the throttle position sensor?
Computer? I wonder if a wire to the computer has shorted out to ground.
SOURCE: my 2005 chevy malibu classic wont start the
This could be a bad starter. Does it make a clicking sound when you turn the key? Does the engine sound like it wants to start but just wont? If the ignition switch is bad it could be the solution to your entire problem and it is not too hard to replace yourself. Please post with these answers. Thank you!
