Question about E-Machines eMachines Desktop PC
Need to access intel graphics application
I have an emachines t5026 and i set the frames per second (i think thats what it was) to high for my monitor and i need to access the intel graphics application for the vga port. any help would be much appreciated
    President:
  • E-Machines Master
  • 1,314 Answers
1. Turn on the computer.
2. Access the safe mode screen. To do this tap on the F8 key after the logo goes away on the screen until the safe mode menu appears. Select VGA mode.
3. This will boot into 640 x 480 resolution, everything will be very big. Now you can go into the properties and select a mode that your monitor can handle.
4. Finally, please rate this solution as fixya as I have answered your question completely with the information you gave me. Thanks! :c)
Posted on Jan 25, 2009
How do I install ethernet drivers for windows xp on T5026 emachine
Using another PC, download 3DP Net (http://www.3dpchip.com/3dpchip/3dp/net_down_en.php), put it in a pen drive and run it on the T5026. This program can install most Ethernet adapters even offline. Normally I would go to the manufacturer's website and download the driver from there but I could'n find this one.
Dec 19, 2017 | E-Machines T5026 (RBT5026) PC Desktop
What are the hardware requirements for this motherboard in the way of memory, and graphics card? I have a pc2700 256M chip that is only seeing 191M of the total ram. Does it require ddr pc2100 instead? And...
Jeff, some of the system's ram memory is being borrowed. If you are using Integrated Graphics, this is where it is going.
[Integrated Graphics is also known as OnBoard Graphics.
On the motherBoard.
The GPU is soldered to the motherboard. (Hence you plug the monitor cable into the motherboard, via a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector )
A dedicated graphics (adapter) card has it's own GPU.
(Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU ]
Integrated Graphics uses some of the system's resources. The Processor, and Ram Memory.
A dedicated graphics card has it's own Processor, and Ram Memory.
(GPU, and graphics ram memory)
PC2100 is DDR Sdram that operates at a frequency rate of 266MHz.
PC2700 is DDR Sdram that operates at a frequency rate of 333MHz.
http://en.wikipedia.org/wiki/DDR_SDRAM
[Frequency Rate:
Proper 'computer speak' for Speed.
'Speed' is slang.
DDR Sdram:
Double Data Rate Sdram
Synchronous Dynamic Random Access Memory
MHz.
MegaHertz
Mega = Approximately 1 Million
Hertz stands for Cycles per Second.
PC2100 can operate Up To a frequency rate of 266 Million Cycles per Second.
PC2700 - 333 Million Cycles per Second ]
No, using PC2100 is going backwards, and will not help increase the Amount of ram memory, seen by the computer.
According to eMachines Support, the T2642 desktop computer's motherboard, uses an Intel 845GV motherboard chipset.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2642
[Chipset, and Chip are slang terms for I.C.
Integrated Circuit.
The motherboard chipset used for the technology of the T2642 motherboard, is the Northbridge, and Southbridge chipset.
(Motherboard's for the Intel Core i3, i5, and i7, do not use this motherboard chipset technology)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Memory Slots = Ram Memory slots ]
The Northbridge chip handles the faster processes of the computer.
The Processor, Ram Memory, and high speed graphics.
High speed graphics being AGP, or PCI Express.
Not a graphics card inserted into a PCI slot.
Integrated Graphics, or a graphics card inserted into a PCI slot, is a slower process of the computer.
Slower processes of the computer are handled by the Southbridge chip.
Northbridge (computing)
vhttp://en.wikipedia.org/wiki/Northbridge_%28computing%29
(At the end of the Northbridge article's first sentence, you will see - southbridge, in blue.
Left-click on it for more info on the Southbridge)
Continued in a Comment
Aug 06, 2010 | E-Machines T2642 PC Desktop
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
I have a Silicon Image 164 ADD DVI card added to my HP desktop DVI-D access card in an effort to get a dual monitor configuration. I get an exact clone in the second monitor. I have an HP compaq desktop...
If the Intel graphic card is part of the motherboard, you need to disable this in the BIOS. You need to install the Silicon grpahic driver, then you will be able to configure the screen resolution etc for each monitor.
Jun 10, 2009 | HP Compaq d530 CMT PC Desktop
How to pick the right motherboard for eMachines T5026?
Heres what i found:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5026
Intel® Pentium® 4 Processor 519
Operates at 3.06GHz
1MB L2 cache and 533MHz FSB
Operating System: Genuine Microsoft® Windows® XP Home
Chipset: Intel® 915GV chipset Memory: 512MB Dual Channel DDR
Expandable to 4GB Hard Drive: 160GB Serial ATA 7200rpm, 8MB cache Optical Drives: DVD±RW, 16x Multi-Format double layer
CD-ROM drive - 48x max write Media Reader: 8-in-1 digital media manager Video: Intel® Graphics Media Accelerator 900 w/DirectX® 9 support
Up to 224MB shared video memory Sound: Intel® High Definition 6-channel audio (5.1) Network: Intel® PRO 10/100Mbps integrated Ethernet Modem: 56K ITU v.92-ready Fax/Modem Peripherals: Premium multimedia keyboard, 2-button wheel mouse, amplified stereo speakers Ports/Other: 7 USB (1 in Media Manager, 2 in front, 4 in back), 3 IEEE 1394 Firewire (2 in front, 1 in back), 1 VGA external connector, 1 serial, 1 parallel, 2 PS/2, 5 audio (2 in front, 3 in back
If you need to replace the motherboard, it is most likely proprietory which means it can only be from emachines so you can request an RMA at the link.
Nov 10, 2008 | E-Machines (308714) Motherboard
Need Info On My Motherboard
You can download the manual from Intel at http://cache-www.intel.com/cd/00/00/21/84/218428_218428.pdf As for the graphics card, get a new one. A medium to high end card will support two monitors if you need it. Regards, Denis
Oct 09, 2007 | 4D INTEL BOXD945PSNLK INTEL 945P CHIPSET...
Power Supply Problem
Hi, I came acroos a similar problem on an older model of emachine. If I remember it right what I did was to update the chipset and agp and other drivers (especially the lan card). The T5026 uses Intel 915GV. Most of what you probably would need can be found at http://downloadfinder.intel.com/scripts-df-external/Support_Intel.aspx?lang=eng. Most of the updates are chipset and OS specific. Good luck and please let me know how this works out for your. Cheers.
Apr 09, 2007 | E-Machines Emachine T5026 power supply **...
E-Machines eMachines Desktop PC Logo
48 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
