Question about HP DeskJet 5150 InkJet Printer
HP Deskjet 5150 poor print quality
Some lines of text print are OK, some lines are barely visible. Color printing is fine. I have plenty of ink left in the cartridge, I have cleaned and calibrated the printer, and cleaned the printer portals as instructed. Still don't have consistent text printing. Any solutions or ideas?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Posted on Jun 25, 2013
2 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: I am having poor quality with black cartridge and
Cold be a fualty print head I would have to be there physically to see tho, try buying a printer maintence kit from a print supply store that should shore this problem up.
Posted on Jul 18, 2009
No color
try to head clean your printer..
follow this steps
1.click start
2.than click printers&faxes
3.right click on hp deskjet printer logo
4.select printing preference tab
5. click on maintenance
6. click on head clean
do it once and try to print some picture with best quality print setting.. and than try to print normaly again.. repeat the steps until the printer normal.
hope this help..
Apr 30, 2010 | HP DeskJet 5150 InkJet Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hp 5150 deskjet says that it is low on color ink
The low ink warning is actually normal for remanufactured cartridges. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. The prints should still be the same quality. You can either press the "Resume" or "OK" button to continue printing, or go into your printer settings and manually disable the ink level indiactor.
Feb 07, 2009 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
COLOR NOT VIVID
The DeskJet 940c is not really the highest quality printer out there on the market. However, having said that, the printer is still capable of producing decent quality printouts. You might play with your printer settings for print intensity, lightness, ink volume.
May 10, 2008 | HP DeskJet 940c InkJet Printer
Problems with Color printing
Click Start - All programs - HP - HP Solution center.
Click Settings - Print settings - Printer settings
Click on the Features tab. Set the print quality to best. Click on the Colors tab. Under color management - Enable the option Managed by Application. Click OK . close solution center. Try to print.
Dec 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP DeskJet 5150 InkJet Printer Logo
204 people viewed this question
Seeker5211
Seeker5211
