Kyocera 5300 error message 'Error.Power Off.F46F'
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
anantakumarj
  • 330 Answers
SOURCE: i'm having an error on
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
Posted on Sep 24, 2009
n25an
  • 622 Answers
SOURCE: Error message - "chassis locked"
check the toner on the left had side is a locking mechanism... make sure toner is in correctly and that switch is locked...
Posted on Dec 24, 2009
mb350sl
  • 73 Answers
SOURCE: I get an error message
The code 6 is a 'fuser' error code. It means that their are defective parts (like a blown lamp or thermistors/fuse, etc. It will require service.
Posted on Sep 24, 2011
oxenmonz
  • 21 Answers
SOURCE: Hi! I've got a KM 1650 it boots up then it say ready to copy after few second now printing then C400 error occur please help. kyocera KM 1650 error now printing then c4000 error comes up
c4000 polygon motor sychronize error, try to cleaning polygon, if not effective, need to replace new polygon.
Posted on Nov 05, 2012
Testimonial: "thanks it help alot"
What does F46F error code on a kyocera mean?
First you have to upgrade the firmware to the latest. If the error code appears again, then you have to replace the main pwb assy (controller).
Aug 14, 2014 | Kyocera FS1370DN Laser Printer
Kyocera fs9130dn
Broken cleaning lamp wire
While the cleaning lamp is on, the broken
cleaning lamp wire detection signal
is detected for 2 s continuously.
Jul 24, 2014 | Kyocera Office Equipment & Supplies
Error Code F46F
Upgrade the system firmware
May 19, 2014 | Kyocera FS-C5300DN Laser Printer
ERROR CODE F46F
replace the driver and check the files your sending one or the other is corrupt.
Oct 30, 2013 | Kyocera Mita Office Equipment & Supplies
My Kyocera FS-1116 MFP says 'printer error'/'engine panic'.
If you get the Engine Panic error message, you need to turn the power switch off and then back on again. If that doesn't fix the error, contact a service representative to help resolve the problem.
Oct 17, 2011 | Kyocera FS-1016 Printer
Kodak Easy Share 5300 Printer error Error code 6203
Error code "6203" can be resolved as follows:
First, you need to open the access door of the printer and disconnect the power adapter from it.
You then need to wait for at least 30 seconds for the printer to get reset.
As a next step, you can connect the power adapter back to the printer.
You can turn on the printer, if required. Once the printer gets powered up, a message "Printer access door open" gets displayed.
Once this message gets popped up you can close the access door of the printer. get more help for Printer Error Code 6203
Hope this helps you.
Sep 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
1,521 people viewed this question
k24674
