Question about Jamis Boss Cruiser Coaster
How do I adjust the seat angle - Jamis Boss Cruiser Coaster
    New Friend:
    Problem Solver:
  • 18 Answers
At the seat the bolts that hold it to the post when you loosen them the seat angle can then be adjusted
Posted on Jan 25, 2013
How do I adjust the seat angle so the front of the seat points more down more
You need six-way power seats. Lower the front of the seat (front button) and raise the back of the seat (rear button).
Mar 25, 2018 | Seat Cars & Trucks
Tip
How to adjust the seat on an indoor cycle
Video of How to Adjust the Seat on your Indoor Cycle
  • This video will demonstrate how to adjust the seat on your indoor cycle properly
  • Tools needed:
    • Adjustable Wrench
  • To begin loosen the nuts on each side of the seat equal turns
    • Ideally, there should be equal portions of the clamp bolt exposed on each side
  • Once you have them loose you can adjust the seat back and forth on the mounting rails as well as adjusting the angle of the set
    • The best position for the seat is level and in the center of the mounting rails adjustment
  • Once you have the seat positioned as desired finger tighten the nuts on each side of the seat equal turns and then tighten the nuts using a wrench an equal number of turns as well
    • Again, the goal is to have equal portions of the seat clamp bolt exposed on each side
  • This is all that is required to adjust the seat on your indoor cycle.
on Jun 06, 2016 | Lemond Revmaster Revolution Trainer
Tip
Indoor Cycle Seat Adjustment
  • Tools needed:
    • Adjustable Wrench
Video of Adjusting the Seat on an Indoor Cycle
on Apr 28, 2014 | Exercise & Fitness
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
Apr 08, 2014 | Tempur-Pedic Furniture
How do you lower the drivers car seat
This is usually a fix position with adjustments being able to be made to the angle of the back rest usually by means of a twisty knob on the adjoining corners. You can also adjust how far or close the seat is in relation to your seat pedals and this is usually done with an underseat handle.
Mar 17, 2012 | Car Audio & Video
The seat on my Scott aspect 40 bike hit my **** while riding very hard and has caused the seat to tilt up now. How do I get the angle back to where it was?
Search engines serve these types of questions better than Fixya because you don't have to wait for one of us to get curious or motivated to answer it.
"adjust bicycle seat angle" to find videos instantly.
Jul 29, 2011 | Cycling
How do you adjust the seat
Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
Jun 20, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
Dont know how to fit the seat to the bike
1. Tighten the bolt on the seat-post of your bike's seat if your seat is a bit shaky. You may need to replace this bolt if it is rusted or withered.
2. Adjust the pitch angle of your seat if it is uncomfortable. You can have it level, leaning forward or leaning backward depending upon what is more comfortable for you. Use an Allen wrench (Allen key) to loosen the bolt on the-seat post to adjust the angle.
4. Tighten the tension on the cover of the seat if the seat has one and it is loose. If it has 2 straps underneath the seat attached with a hook, release it from the hook and tighten, then re-hook the straps.
May 15, 2010 | Dynacraft 16" Boy's Wheels Bike
How do I adjust the seat angle to be lower on my Terry Fly Tri Gel saddle
Seat post will have an allen head screw that will loosen the fore and aft adjustment.
Sep 24, 2009 | By Terry Terry Fly Titanium Saddle Men's
Jamis Boss Cruiser Coaster Logo
136 people viewed this question
Top Jamis Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Jamis Cycling Expert? Answer questions, earn points and help others
