Where can I get a user manual for Carslbro Marlin 8400 DSP power mixer amplifier
Powered mixer Amp used for PA system
  • 134 Answers
Here is a pdf link. Sorry I couldn't get the "add a link " button to work. Copy and paste in browser.
Posted on Apr 28, 2017
    Top Expert:
  • Audio Player... Master
  • 40,324 Answers
Try Googling (Carslbro Marlin)(8400 DSP)(manual) without parens.
  • 54 Answers
SOURCE: KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
Posted on Nov 03, 2007
  • 1512 Answers
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
Posted on May 13, 2008
  • 218 Answers
SOURCE: Puchased A Yamaha DSP-A1092 Amp from Auction turns off
I doubt it. Sounds like it is going into protection due to bad output transistors or some such. Time for a trip to the repair shop it sounds like.
Posted on Nov 14, 2008
  • 211 Answers
SOURCE: Buzzing in speakers on Carlsbro Marlin 8400 Power Amp
If your volume is down and there's a hum, then it could be that your capacitors in the power supply are blown. Also there could be a problem with the bridge rectifier, possible that there's 1 or more diode's defect. Any technician can reapir that.
Hope it helps,
Posted on Jan 31, 2009
  • 1175 Answers
SOURCE: user manual for 40 watt pa amplifier (32-2054)
Posted on Apr 01, 2009
Mixer to P.A. system connection
You'll want to use the Stereo Out connections at the top right. You might need adapters to plug into whatever system you're trying to use. Also note that this mixer does not provide power, so the speakers you're using have to be self-powered or be driven by a separate amplifier. You would then plug the Stereo Out connections into the INPUTs of the amplifier.
Jun 28, 2013 | Nady Systems Nady SRM-10X 10-Input Mixer
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
I dont know how to connect my gem sound trf152 speakers
Looks like it takes regular home theatre speaker wire. If this is a powered speaker (like a JBL eon g2), then all you need is a passive mixer, and connect the speakers to the mixer. If this is not a powered (amplified) speaker, then you will need an amplifier to boost the sound source and drive the speakers, so you would connect the mixer to the amplifier, then the amp outs to the speakers.
Apr 14, 2012 | Gem Sound TRF152 15 Pro DJ PA Speaker
Can i go straight out of the pre out on my fender frontman into a powered mixer pa system
yes,, Pre means before powered or amplified ,, so yes you can do this to a powered mixer, just be sure that the power is off before making any connections,, without the ground of the rca cable touching , the blast to the speakers can invert the cone !!
Aug 26, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
The relay switch clicks but does not power up my yamaha emx300 pa amp/mixer.
I have one like it in my shop
The main power transformer has gone bad
Yamaha has them in stock
Aug 04, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Connecting two powered mixers
Hi, If you have small electronics knowledge this might help you. First fine in each mixer the amplifiers line In if your mixer has two amplifiers then you have four line In. Disconnect this line from your mixer and build a circuit Line out multiflier. You can use op amp for this application this is a simple circuit. You made two input and four outputs. If you are interested i can send you a schematic diagram.
Aug 10, 2009 | Audio Players & Recorders
Hope it helps,
Jan 20, 2009 | SpeakerCraft MZC-66 Amplifier
Lightning strike to powered console.
On a generic level, without knowing the specifics of your equipment, I.E. amp & mixer make/model, you start at the mixers input stage. If an amplifiers output transistors die, they usually cause the amp to trip or blow a fuse, the weakest point in the system. If the amp is not doing this then the chances are, it's an line level problem, mixer related.  Again, you have to list the equipment you have in order for me to be more specific.
Nov 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
431 people viewed this question
