Question about Xerox Phaser 3600DN Laser Printer
ADC not confirm error - Xerox Phaser 3600DN Laser Printer
    Passionate:
    Visited the website for 10 consecutive days.
  • Xerox Expert
  • 129 Answers
That is a fuser error, you will need to replace the fuser, the part number is 126N00324.
Posted on Jan 18, 2013
Xerox workcentre 6015 092-651 error
That error indicates a bad ADC sensor. Try cleaning the adc sensor which is on the rear of the transfer belt. If that doesn't work, replace transfer belt as sensor is not sold separately.
Sep 18, 2013 | Xerox WORKCENTRE 6015/Ni Color
Adc sensor error
adc sensor error / error 092-651 .....docu print cp205....please help me...i cant find the solution....
Jan 21, 2013 | Xerox FUJI DOCUPRINT CP205 COLOR LASER...
Service req e547
I can tell you that a Engine Service Error Code #E526, stands for a "SOILED ADC SENSOR". ADC stands for "Automatic Density Control" [sensor]. Hopefully, you will have your printers "User's Manual/Owner's Manual" and it will show you exactly where that ADC Sensor is located, because I do not know. I think its a removable board, that probably slides in and out, somewhere near the upper right section on the inside of the front of the printer. If you use the round knob [on the inside of the printer, near the center] as the center of a clock, then I would guess that the sensor board assembly would be around the one-o-clock to the two-o-clock position, but really don't know for sure...Basically if there are any parts of wrong specifications used, improper mounting, damage, distortion, dirt, or adherence of any foreign material, that can cause that particular error code. Hopefully the ADC Sensor is just dirty and needs cleaned. The major parts that need to be checked, are the "ADC Sensor Assembly", the "Main Harness Assembly" and the "MCU Printed Circuit Board". E532 error means there's a drain on one of the several motors within the printer. Reseat all the consumables within printer (especially the waste toner)and the paper tray the error clears. If the error doesn't clear then you have a real hardware fault and the job of changing each motor until you get the right one. This particular printer has a problem with waste toner. The toner seems to clog up and be the main cause of this error - you may find this occurs after the printer has been sat idle for sometime i.e. after a weekend. Once this particular printer starts giving this message its best to run through this routine each morning... open the front cover, unlock the two lockovers, pull out the consuambles about half way and then slam them back in - hard enough to loosen the toner but not hard enough to break the printer. Switch it on and it should remain error free all day.
May 27, 2010 | Epson Aculaser C1100 Printer
Samsung clp610nd ADC Power Slope
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Nov 12, 2009 | Samsung CLP-610ND + Demo Laser Printer
My docucolor 12 say 9-612 error in the adjustment
9-612 TRC RADC Out Of Range RAP Initial Actions Clean the ADC Sensor. Clean the IBT Belt. Check that the P/J139 on the ADC Sensor PWB, IBT connector J702A, J702B and P/J416A on the IOT Drive PWB are firmly connected. Videc
siriusdigitalbox@gmail.com
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
ADC for ECG signal
example of design circuit using OTA to detect EMG/ECG signals.
Feb 27, 2009 | ADC Medical
Xerox Phaser 3600DN Laser Printer Logo
1,339 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
