Question about Samsung Refrigerators
Vertical hinged section is broken
The spring is broken
5 Suggested Answers
mewms_14904
  • 1027 Answers
SOURCE: presario laptop hinge broken.
Well since we don't know what model presario you need help with, go to this site and search for tech manuals. once you find the model read what the manuals are for e.g. service manual.
Read carefully these might be multi-part manuals 0-5
read carefully the printing on the page is small and it is easy to overlook the "To download file please click here"
Posted on Apr 18, 2008
  • 7 Answers
SOURCE: Right hand hinge broken
Buy replacement hinge assembly & replace. Quite a simple job & shouldn't take any more than 20 minutes to do.
Posted on Aug 17, 2009
SOURCE: broken door spring on kitchenaid dishwasher
kitchenaid should be made to recall all of these dishwashers that have that string holding door since it could pose a hazzard to children. They should be made to put in a metal cable at no cost to the consumer
Posted on Jan 29, 2011
brianmcevoy4
  • 41 Answers
SOURCE: Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Posted on Jan 22, 2015
How do you put a spring into the vertical hinged section?
Best way is DO NOT use the spring.Use a common elastic at the bottom of the folding flap run around the flap to a short small screww you would drill into the plastic under the door.This lasts longer than the spring and when it gets tired,just replace with another elastic,lasts for years and works better.
Jan 29, 2016 | Samsung RF265AA Bottom Freezer French Door...
How to remove the oven door
On many models with the door open there is a screw on either side of the door on the inside. Each screw secures the door to the hinge. Remove the screws lift the door back to the near vertical rest position and carefully lift the door out from the hinges.
Caution the door is heavy!! The door must be in the near vertical position to have the hinge in a neutral location. There is significant spring pressure on the hinges. The door should be partial open held in a neutral position before attempting to lift up.
Dec 01, 2015 | Ovens
Suspect door spring/assembly broken. How do I repair same?
If it's like my whirlpool, pull it out. Spring should be obvious. I doubt the hinge portion is broken. Spring may be. While it's out and springs tend to break, I would replace both. Several online appliance parts stores can help you with springs, my diagnostics and Hinge issue. They have been helpful to me.
Apr 02, 2015 | LG 24 in. LDF 7811 Stainless Steel...
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
Why did my thread take up spring break? And what do I do now?
Type www.fixsewingmachine into your web browser and when page comes up, click on yellow section left-hand side of that site page titled TIPS. All FREE info, instructions, videos. Jimmy
Apr 04, 2012 | Sewing Machines
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
Broke the hinge on my Samsung Alias 2. Need to repair it - have the parts! I had earlier broken my LCD and took the ****** apart, and put a new LCD in. Works fine, but not all of the original screws and...
The spring goes under the little plate that is held in by two tiny screws. Its visible when the phone is open vertically with the plastic cap removed from the hinge. Hope this helps. I took my hinge apart after I dropped it and the top half came off... now it's just holding by the ribbon so I'm going to order a new hinge. Verizon is completely useless. They don't want to even know about you if you're phone isn't under warranty and I have 11 months till an upgrade...
Jun 29, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
Passenger door hinge spring mechanism is broken 97 gmc jimmy
The spring is likely "broken" because the pins in the bushings are worn. It's a common failure point on many GM vehicles. The hinge pins, bushings door check roller and spring can be replaced at most body shops for about $150-200.
Apr 23, 2010 | 1997 GMC Jimmy
The piece that connects the vertical hinge to the door is broken.
Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
Mar 16, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerators Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
