Question about Viper Security and Remote Start System (basic install included)
Viper 771 Remote start/Alarm
When i attempt to remote start the engine wont even crank over. if i have the vechicle started by key and swith over the to remote from there when i remove the key the engine dies.
  • guardian102 Jan 28, 2009
    Found out one of the 12 volts wires melted and thats the issue
  • 905 Answers
The viper alarm is malfunctioning , it is supposed to bypass the key ignition and or chip in the key to allow it to start , you will need to look for a reset button( under the dash and just two wires going to the button)( stuffed under the dash ) ( not the switch) , this should let you start it but if the alarm components that control that bypass is to far gone then this will not help and the alarm will need repair , replaced or removed
Posted on Jan 28, 2009
  • jason Jan 28, 2009
    well these alarms are failing in the the bypass circuit , so I am just speading the word , as I don't have ESP , but I know these circuits are failing , and yes there is always other possibility's for a fault
    so it did need repair
After starting it runs only seconds then cuts off
Compustar monitors your vehicle's engine to validate remote start activity. In the event your engine cannot be detected, the remote start operation will be cancelled after (3) three unsuccessful attempts. Additionally, you could receive error 8, error 08, or even error 01 on your LCD remote when you have this issue.
Troubleshooting:
  1. Start your vehicle's engine with the key.
  2. Press and hold the foot brake down.
  3. While keeping your foot on the brake, press the KEY or remote start button button for 3 seconds.
  4. Release the foot brake and remove the key from the ignition.
If you continue to experience failed remote start attempts, please contact your original installer or authorised dealer for assistance with this issue.
Apr 03, 2016 | Vehicle Parts & Accessories
Why doesn't remote start work?
It says its a Viper alarm system. . If the alarm system is active, reprogramming the ignition keys was a waste of money. The problem is in the control box for the viper alarm system. It has disabled the ignition because it thinks that is being broken into. there are sensors that monitor the the vehicles vibration and is probably a problem with one of the sensors or maybe even the control box itself.
Dec 24, 2015 | Remote Start System
My remote locks & unlocks but wont start
When you attempt to start the vehicle with the remote what happens?
Feb 12, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2005 sedona alarm
Please be more specific. Is it the factory alarm going off when you remote start or, is it the Viper alarm going off when you start the car with the key?
Jan 24, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car wont start
You need to be very quiet for this test, but try turning the ignition key until dash warning lights are on, but without cranking the engine. Listen for whirring noise from fuel pump in the gas tank. You may even lift out the rear seat base, to pick up any sound as best you can. If you can't hear anything from several attempts then it's likely you have a failed fuel pump. The fuel pump can sometimes suffer damage when running out of fuel.
Oct 30, 2012 | 2005 Hyundai Accent 1.5
Remote Start Ford Exp 2003
try another key, if you install another key with ignition in the on position for 3 seconds warning light off, then turn off ignition switch, then start engine.if engine still dont start and the pats warning light keep flashing and dont turn off in 3 seconds.you need have vechicle pats system scan at dealership, you need diagnostic equipment to trouble shoot the PATS SYSTEMS.many things will cause you problems like fault to ecm to the immobilizer control module,could have worn transponder on key or faulty read coil in the ignition switch lock cylinder.
Aug 25, 2012 | Ford Explorer Cars & Trucks
I have a 2005 suzuki swift, a yellow lock light has just appeared on the dash and now my car wont start . do you have any idea what the problem could be ??
SOUND LIKE VECHICLE IN THEFT SECURITY MODE CAUSED BY WORN KEY OR IMMOBILIZER READ COIL.PROBLEM IN THE BCM AND ECM.TRY INSTALLING KEY IGNITION SWITCH.TURN SWITCH TO THE ON POSITION FOR 10 MINUTES UNTIL THE YELLOW LOCK LIGHT TURN OFF OR DISAPPEAR.THEN TURN OFF IGNITION SWITCH FOR 5 SECONDS, THEN TRY START VECHICLE.IF VECHICLE STILL DONT CRANK.HAVE VECHICLE CODE SCAN FOR THEFT SECURITY FAULT CODES.
Jun 19, 2011 | 2005 Suzuki Swift
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
428 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
