How do I change my alba lcdw16hdf tv to analogue
Alba lcdw16hdf hasa digital sky aerial but will not accept sky. Someone told me I must switch the tv to analogue, but haven't got manual to tell me how.
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
Chris.
Posted on Jan 31, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 8457 Answers
SOURCE: Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Posted on Aug 15, 2009
flyingfrog
  • 3 Answers
SOURCE: My Phillips SLC4 flat screen TV has suddenly
The problem has cleared itself a day later after being switched on/off a few times.I suspect the 'computer part' of the TV (channel processor, instruction decoder etc) received maybe a power glitch or an illegal infrared instruction (2 remotes used at once for example) and 'locked up' leaving just the analogue side operating.
I was going to continue happily using it with just the analogue side slaved to my Hd recorder for digital signals but it seems to have got over whatever it was that upset it.
Posted on Sep 09, 2009
Cannot tune in my 19 inch Alba tv to main channels ie bbc and itv
POOR AERIAL SIGNAL, CHECK THE COAX JACK IS ON PROPERLY. NO OUTER STRANDS OF WIRE SHOULD BE TOUCHING INNER COPPER CORE. OR CHANGE CABLE & GO INTO THE BACK OF A SKY BOX TO THE TV, THEN RESCAN.
Jan 15, 2017 | Alba Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Sky problem
Freeview has nothing to do with satellite. FreeSAT is the one that uses a satellite dish for reception. FreeVIEW is received through the aerial.
Also, don't fall for the "digital aerial" scam. I install aerials as part of my business. I've been to homes with aerials 20 years old, covered in soot from the chimney and they still pick up Freeview perfectly well. Equally, I've been to homes where the owner has bought some gold plated multi-finned "digital high gain" monstrosity that has awful reception characteristics.
If your TV aerial is okay, then just plug it in to your Freeview receiving TV and do the tuning.
If you do want Freesat then you will need a satellite dish along with a Freesat receiver.
Sep 04, 2014 | Televison & Video
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
Can you watch the same sky channel on 2 tvs
Yes if you use the rf2 out on the box, cable it to the aerial input of the tv in the other room using uhf coax cable (aerial cable), and tune the tv in analogue mode (not freeview but the old analogue) to the sky box. It's usually on CH68 but if you do an autotune it should find it. Of course you will only be watching in SD not HD on the second set.
Jun 19, 2014 | Computers & Internet
Baird tv
Two things you can try:
Check the remote control and press the button for Digital input. Someone may have set the tv to expect an analogue signal from the aerial while you were pouring your wine. Because the analogue tv signal has been switched off the tv won\'t be receiving anything off-air. It will need setting back to digital to receive Freeview.
OR
The television set may be dropping itself into "AV" mode and is expecting an input through a SCART or HDMI socket. Sometimes an external device (video or DVD player) will hijack the television if the set-up hs been configured for this. Try unplugging all external devices (Sky box, DVD, VCR, games console or whatever you have plugged in). Make sure that the telly is configured to digital input and tuned to BBC1. Then see if the it will show the programme.
If the television is actually broke then you should return it if it\'s still under guarantee.
Jul 15, 2013 | Televison & Video
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
