Question about Universal JXD S18 4.3"" Resistive Screen Android 4.0 Mini Pad Tablet PC w/ TF / Wi-Fi / G-Sensor - Black"
How to reset jxd s18
I just got a jxd s18 and started to use it and now after having it less that 24 hrs every time i touch the screen it has a blue dot or if i move my finger up and down there is a blue line i was thinking if to reset it or rebeet it if that will work to stop that how can i fix this problem or send it back to the company
I can charge my tablet jxd S-6600-M6 more then 50%, as a result my device work less then2 hour
the nickle cadmium battery in your tablet has developed what is know as 'battery memory' due to improper charging practices. Time to replace the battery.
Feb 09, 2015 | Tablets & eReaders
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
I used my table and the battery died. I plugged it in to charge and the tablet wont turn on at all and its been charging for almost 2 hrs. Is there anything i can do? its a 7" irulu with android 4.0
google search netflix 1.8.1 apk download
click on the link that has dropobox at the end
then click on blue download icon
afterdownload is complete locate and proceed to install......
enjoy actually watching and hearing your movie
Feb 17, 2014 | Irulu 7" Google Android 4.0 Capacitive...
How can i remove username and password from tablet jxd s6600
Tap 'Applications' to open the main apps menu and then tap 'Settings'. You may need to sweep with your finger to a new screen of shortcut icons before you can see 'Settings'.
Tap 'Location and security' then tap 'Set screen lock'. Next tap 'PIN' to set up a pin number for the lock screen.
here you can set and reset your password
Aug 09, 2013 | shop-fun JXD S6600 7 inch Android 4.0 All...
How do I change the language?
how to change the language from chinese to english
Jan 22, 2013 | Universal JXD S18 4.3"" Resistive Screen...
MY JXD S18 MINI PAD IS IN CHINESE HOW DO i CHANGE IT TO ENGLISH
its an android system so it wont be diferent from a cell or even a tablet. put side by side with one or other and follow the steps necessary.
hope it helped
Jan 05, 2013 | Universal JXD S18 4.3"" Resistive Screen...
My daughter forgot her pattern password is therre a way to reset it
have u tried to hold the power button down with volume button down at the same time and see if it will reset to factory settings?
Dec 29, 2011 | Tablets & eReaders
Universal JXD S18 4.3"" Resistive Screen Android 4.0 Mini Pad Tablet PC w/ TF / Wi-Fi / G-Sensor - Black" Logo
319 people viewed this question
Top Universal Tablets & eReaders Experts
rhodesworks
Yoav Shilon
Yoav Shilon
Lesley Cameron
Lesley Cameron
Are you an Universal Tablet and eReader Expert? Answer questions, earn points and help others
