Question about Holmes Products Heating & Cooling
I have a Holmes hch6001 electric heater when I turn it on the fan runs faster than normal and it will not heat up
When you unplug for 10 min the first time it comes it heats up then fan comes heats to set temp. then when it comes back on the fan runs faster than mormal and the unit will not heat up..
hotuna
  • 288 Answers
SOURCE: thermostat does not stop heat pump unit
Most of these problems are the program settings on these way overcomplicated thermostats. You will need to re-read the instructions on setting the programs. Or bite the bullet and buy a cheaper and simpler one. If you installed it yourself, make sure the settings on the inside are correct, like gas/electric heat, and 24 volts, stuff like that.
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Posted on Jan 12, 2009
SOURCE: my oil-filled Holmes heater HOH2520U
I had the same problem. this is what i did. unplug the heater. removed the plastic panel to expose the control panel where the blinking light is.  Removed all the dust and cobweb build up, then using rubbing alcohol, wiped the white residue that was on the green circuit board. I did this 10 days ago and the heater has been working fine since then. chaz
Posted on Apr 04, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Posted on Nov 03, 2009
kdgrayson
  • 195 Answers
SOURCE: Holmes 1 Touch Tower Ceramic Space Heater
YES
Posted on Dec 03, 2009
Testimonial: "Better safe than sorry is the message and it is well received..He was very helpful and thoughtful enough to include the warning..."
Space heater stops working after 2-3 minutes
The problem is most likely the over heating sensor thermostat located directly under the heating elements - The reason the over-heat safety thermostat sensor is tripping the warning buzzer is because either the cool air fan intake is obstructed with dust / dirt, or the fan motor stopped rotating, or the over-heating condition thermostat is defective, or over sensitive - Usually when the cool air intake is obstructed for any reason, the heating elements will glow brighter, and hotter without good air flow, and the elements may start to bow downwards closer to the over-heating safety thermostat - However, if the safety thermostat is defective, it can trigger the warning buzzer even though there may not be an over-heating condition / event present - The buzzer warning going off prematurely also occurred with my Holmes space heater - I checked the air flow first, and then the appliance tip-over switch second - Both were found functioning properly - It wasn't until I replaced the safety over-heating thermostat, did the buzzer stop going off moments after I plugged the space heater in an outlet.
Jan 05, 2014 | Holmes Products HRH316 Mid-Size Heater
HCH6150 heater runs for a bit and then just stops
Open it up and clean with an air can, most common cause is due to overheating.
Dec 17, 2011 | Holmes Products HCH6150-U Ceramic Compact...
Hello I have a Holmes HS700 and it has been great until now. I was trying to dry something by tilting the heater but then realized it turned off each time I tilted it. Needless to say after a few...
Ed, try turning OFF the Master ON/OFF Switch and unplugging the unit. Wait 12-15 minutes and plug it back in. Turn the Master ON/OFF Switch to ON and set your controls as you normally do. Hopefully the heater reset itself turn that 12-15 minute timeout. In the future don't tilt the heater and activate the tilt switch. Its like a Pin Ball Machine, you loose your turn if you tilt it.
Hope that helps to solve your problem.
Apr 14, 2011 | Holmes Products Heating & Cooling
My Holmes modelHCH 6001 won't start. The receptacle is hot so I think it has to do withthe product itself.
It may, but it could also be a faulty receptacle depending on how old it is or the amperage draw from the heater may be to high. Especially, if you have another electric appliance plugged into the same receptacle. That's where you need to start troubleshooting. If the wiring and the receptacle is fine, then there is more than likely an electrical short in the heater or the cord from the heater to the receptacle.
In the meantime, unplug the heater from the receptacle and let it cool while you do the troubleshooting. If you decide to remove the receptacle, be sure to turn the circuit breaker feeding that receptacle to OFF. Or you may have a shocking experience.
Mar 18, 2011 | Holmes Products HCH6001 Heater
The Holmes Comfort Temp ceramic heater works fine on Low setting, but once it is set to High temperature the illuminated digital display fades out and the unit turns itself off. Unplugging and letting the...
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Jan 19, 2011 | Holmes Products HCH4953-U Ceramic Compact...
Holmes Heater HCH 4163 purchased 2 years ago & has seen only light duty. Upon turning heater on there is a severe electrical smell allthough heater appears to function normally; cord & heater do...
I think the warrenty on this heater is one year. If the heater housing and cord are not overheating then I would remove back panel and clean fiter and brush,vacumn,or use compressed air to clean motor and fan blades. It's possible that if you have not been using very much that it's just burning off debris and causing the smell. I hope this helps you. Thanks
Dec 20, 2010 | Holmes Products HCH4163 Ceramic Compact...
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
Heating & Cooling Logo
62 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
