A215 Black Screen
I turned off my laptop. When I turned it back on, I had a black screen. All the lights wer on, fan was on, however, nothing on the screen, it didn't even sound like the hard drive was responding. I took it in to be repaired and they said the GPU was bad and the only way to fix it was to replace the mother board. I set the computer aside fro a few months. Then I had another computer go bad. I used the CPU from the Toshiba and it fixed the other computer. I then put the bad CPU in the Toshiba. Amazingly the Toshiba was fixed. After about an hour, it went black again. This time I was sure something was frying the CPU. A couple of weeks later, on a whelm, I replaced the battery. Once again the computer started working. Then I shut it down, and got the black screen again. Now I am convinced the BIOS is corrupted. Any suggestions? Is there an easy way to reset the BIOS without unsoldering the BIOS battery?
  • Rodney Dunn Jan 17, 2013
    Over heating is not the problem. Already cleaned out the lent. Been doing that for years. There is nothing wrong with the screen, as it works when the initial boot starts. The problem is, the initial boot is not happening. Hard drive and RAM work in another computer. Janis, I have other computers, just was trying to get this one working for the kids.
  • Janis
    Janis Jan 17, 2013
    Okay
  • 1,824 Answers
I would recommend you to just buy a new, good, Dell laptop!
Posted on Jan 17, 2013
3 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: dell XPS M1330 laptop doesn't boot just shows colored lines...
Multiple problem issue going on here, with the screen having those lines popping up the way it is, the screen is definitely going to need to be replaced.
Hard drive is a more touchy issue. Not sure if you put a new one or a refurhbished one in the system. If it was a used one or refurbished one, I would suggest putting a new one in the laptop to be sure the hard drive is good and then reinstall the OS and put the drivers back on. That would be my suggestion.
The other thing to try would be to make sure your memory is good. If you have more then one stick, try each stick one at a time and turn on the laptop after inserting just one memory stick into the drive, and then repeat the process with the other and see if the laptop does the same thing each time, if it does then you know the memory is good, if you can get it to boot up into windows with one memory stick but not the other then you know one of the memory sticks is bad.
In fact try the memory swap first and then if that doesn't get you anywhere then try a new hard drive in the laptop.
If that doesn't get you anywhere then you know for sure the motherboard is bad.
Posted on Sep 04, 2009
  • 10 Answers
SOURCE: HP ZE2000 blank screen on start up.
you need to change the lcd inverter card of your note book
Posted on Oct 21, 2009
Acer aspire 5515(laptop) screen is black turns on screen stayscompletly black...no acer logo nothing just a black screen. power button comes up green u can hear the fan and harddrive start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Acer Aspire 5100-5033 Notebook
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
I have a toshiba satellite A215 S7422 Before i had problems with the cooling fan and i had to replace.It was turning off after 5-10 minutes.I Ordered a new fan online, replaced and i was good to go....
Can you hook the laptop up to an external monitor to see if you get video...otherwise we'll have to try some other stuff that requires a bit more time.
Oct 02, 2010 | Toshiba Satellite A215-S7422 Notebook
Okay so first off I have ALOT of important docs and what not on my laptop so it is a must that I require these items ! okay So I just got back from Denver and had used my laptop only once and it worked...
Sounds like a graphic card problem. You should be able to remove your hard drive and connect it to a desktop computer and access the drive and get your important files.
Aug 06, 2010 | Toshiba Satellite A215-S5837 Notebook
How to repair satellite a215-S4807 black display?
your user profile may be corrupt. after turning on your laptop press F8. choose "last known good configuration" and see if that resolves the problem. if not, next choose "safemode". from safemode click "yes" to continue and restart the computer from the start menu. if this doesn't work, go back into safemode. click "no", and restore the computer to a early date when it was working.
Nov 18, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
Mar 14, 2009 | Toshiba Satellite A215-S4747 Notebook
Will not power up
most likely the fan has gone bad or the vent slots are all clogged up with dust. get a can off dust off and blow out the vents.
Feb 26, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
Jan 31, 2009 | Toshiba Satellite A215-S7422 Notebook
A 105 screen going black.
try by removing your display adapter in safemode.if problem persists reinstall your display driver.report your findings
Apr 03, 2008 | Computers & Internet
Gateway notebook problem
Black Screen of Death - BSoD Black Screen of Death or BSoD computer dictionary definition and information.
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Gateway 450ROG Notebook
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
