Question about Toyota Vehicle Parts & Accessories
Car alarm arm indicators not working - Toyota Vehicle Parts & Accessories
  • Toyota Master
  • 625 Answers
What indicators are you talking about?
Posted on Jan 17, 2013
I got a 95 vectra when engine off all four indicator lights stay on.
Has the vehicle got an alarm system that flashes the indicator when arming/disarming? if so the relay in the system is holding the lights on possibly requires a new alarm control unit. Hope that helps.
Jan 26, 2014 | Cars & Trucks
Security indicator light goes on when car is turn off
probably just your alarm indicator saying its armed
Jan 08, 2014 | Mazda MAZDA6 Cars & Trucks
2005 chrysler 300c-deactivate anti-theft system
sorry. I can't say because I don't know if you are fixing your car or stealing one.
Best bet is to call the dealership or hit up google.
Jan 20, 2013 | 2005 Chrysler 300
07 softail indicator on left hand side not working. and not working when alarm is armed either. have had new modual fitted by harley dealer and still not working. only faint light on dash when alarm is...
Try the earth connections. Harleys have a very shakey motor, even with the Anti Vibe Mounts. Also check you are getting a feed to the indicators. although the earth is the most likely fault. You could try removing and refitting the indicators and cleaning the mounting points with some scotchbrite before re-assembly.
Feb 12, 2012 | Motorcycles
I have installed a cyclone alarm on my bike but now my indicators dont work unless I'm arming the alarm and my dials dont work but do light up :'( my bike is a gsxr 600 srad 2000 model
Sounds to me like you have made an error somehere, the indicators are not meant to be cut only just cut back the insolation and solder the alarm indicator wires onto the left and right indicators, best to the rear, DONOT CONNECT AT FLASHER RELAY,
Recheck your connections, only cut the system you wish to protect ie imobiliser alarm, follow the instructions carefully if
you have any, slightly grey area, with security devices as the information in the wrong hands could have bad concequences
Sep 08, 2011 | Suzuki GSX-R 600 Motorcycles
My alarm dont go off, but the sensor indicate that its on flash
Lock car with remote,this arms alarm
Then open with key,this checks alarm is working
Apr 18, 2011 | 1999 BMW 323 Series
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
ADEMCO alarm system indicates A/C not ready. What does it mean, how to fix it?
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
Nov 22, 2009 | Honeywell 5804 Ademco Wireless Security...
When i use my key in my doors my alarm doesn't arm mondeo estate
in the door is a switch that tells the alarm to activate start there
Feb 03, 2009 | 2002 Ford SVT Focus
Vehicle Parts & Accessories Logo
20 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
