I have tried to turn on the power to the laptop and nothing is happening I have tried changing the battery and that is not doing anything ?
    New Friend:
  • 4 Answers
Take it to a laptop repair centre
Posted on Jan 17, 2013
MysteryFCM
  • 187 Answers
SOURCE: laptop wont turn on
Unfortunately, it sounds as though your laptops are in need of replacement.
Posted on May 26, 2008
  • 41 Answers
SOURCE: Laptop not working
Disconnect the battery and the AC adapter from the computer.. Hold down the power button for 2 mins. Now connect the AC adapter only..
If it was an issue with the static electricity then it should fix it.
Else try changing the wall outlet and chk if the connections are fine.
If the brick on\f the ac adapter does not get warm then probable the adapter has gone bad and need to be replaced.
If the it still does not work then you can also try reseating the ram and the hard drive.
If all the above does not work then probable the power module on the nb has gone bad and need to be repaired.
Regards,
Anup
Posted on Apr 05, 2009
  • 1019 Answers
SOURCE: acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Posted on Apr 20, 2009
parrotheadpc
  • 2600 Answers
SOURCE: toshiba satellite m35x-s114 boots to the toshiba
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Posted on Nov 27, 2009
  • 62 Answers
SOURCE: Laptop will not turn on.
It is a problem with the Dell Inspiron 1150 system. That system had known problems for overheating. You may need to replace the fans on the system. Call Dell they did extend the warranty on these systems for this particular issue.
Posted on Dec 01, 2009
What should i do with my samsung n150 plus since it has no display on screen when i turn it on and only the led light for the on/off stays after turning on? Please help me.
Have you tried connecting it to an external monitor via the VGA port? It could be that the LCD panel has died. If this happened after coming out of sleep mode or hybernation I suggest pulling the battery, disconnecting the AC adapter and, with no power at all, hold the Power Switch down for a full 30 seconds for a complete power drain. Then reconnect the AC Adapter and replace the battery and test.
It's worked for me in the past - it just might work here.
Good luck,
TIH
Mar 09, 2015 | Samsung N150 Plus 101inch netbook
My fujitsu laptop won't turn on.
If the cooling fan comes on and nothing else happens, it could be a GPU issue and be in need of reballing due to overheating.
Mar 03, 2014 | Computers & Internet
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Computer is not working
The computer may be in hibernate or standby. Try pressing the space bar, and then wait a moment. See if anything happens. If nothing happens, press the power button for one second and wait a moment and see if anything happens. If nothing occurs, you may need to force a restart.
To force a restart, hold in the power button for approximately 15-20 seconds, this should force the computer to turn off all the way. If holding the power button doesn't do the trick - you can unplug the computer from the wall and take out the laptop battery as a last resort.
Once you are sure the computer is off all the way, press the power button and see if anything at all shows on the screen. If you are not able to see any information on the screen, it is possible that the Laptops screen has gone bad. If you have an external monitor you can try to plug into it and see if anything shows. If nothing shows, it is possible the video card/motherboard is gone bad.
To fully diagnose a bad motherboard or video card - you would need to take it to a qualified computer technician.
Nov 15, 2011 | HP Compaq Presario C306US Notebook
The laptop just simply died while watching a blu ray disk. The laptop is brand new and this is my first attempt to watch a movie. I'm not able to do anything cause not even got a life signal from it....
Unplug the laptop, remove the battery, and hold the power button for 15 seconds. Then replace the battery, and try turning it on. Please leave feedback! Thank you!
Jun 10, 2011 | Computers & Internet
When I try turning on the laptop, it does not do anything. I tried removing the battery and putting it back on then plugged the power supply, still nothing works. I have tried isolating the problem by...
I am sorry to say but I do not believe there is anything anyone one here can say that can help you. I think the best thing you can do is bring it in to a shop to get it looked at by someone. (Bring it to a repair center not an electronic store to be shipped out.)
Mar 05, 2011 | HP Pavilion TX2000Z Notebook
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
May 23, 2009 | Acer Aspire 5100 Notebook
Laptop not working
Regards,
Anup
Apr 05, 2009 | HP Compaq Evo n610c Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
