Question about Bosch Dishwashers
Owners manual for bosch shx46a05uc/26 - Bosch Dishwashers
2 Suggested Answers
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
When troubleshooting my shx46a05uc bocsh diswasher it show a flashing light on the delicate/Eco button and regular wash light stays on. What does that tell me?
sounds like the electronic switch usually a Thyristor is not switching when you push the eco button, You could try disconnecting the the machine from the mains then push the buttong in and out a few times to see if the push button has a bit of dust on the contacts..
Sep 18, 2013 | Bosch 24 in. SHX46A05UC Built-In...
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Bosch SHX46A05UC/30 runs for 4 hours.
The circut board in the biege plastic case under the buttons on the right has what is called a cold solder. In other words the solder melts under operational use. Some are repairable and some are not.
1. UNPLUG DISHWASHER or turn off breaker and test for electricity.
2. Remove screws from door panel.
3. Take pic of position of wires going into plastic box.
4. Remove top section of plastic box with buttons exposing small circut board.
5. Open plastic box exposing large circut board and in the middle of it you will see a black spot where the solder has popped. Resolder and reassemble OR replace old circut board and then reassemble.
A new circut board is about $135
Usually electrical parts are not returnable
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-1.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-2.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-3.jpg
Oct 23, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 06, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Model shx46a05Uc/14 not running
Unlikely to be a level problem. Remove the filter and two screws holding the cover over the wash motor impeller from inside the wash tank - check for something jamming the impeller, like bits of broken glass or fragments of bone, fruit pips etc.
If not that, check basics - water supply, drain hose, filters clear, not syphoning empty, etc.
Feb 02, 2018 | Bosch 24 in. SHX46A05UC Built-In...
Dishwashers Logo
173 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
