Question about Dell 5210n Laser Printer
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
The squeak is in the back below the paper exit area. I lubricated the top bearings, but the parts that squeak are below. How can I disassemble it?
    Champion:
    New Friend:
  • 286 Answers
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Posted on Jun 06, 2014
SOURCE: Jams
Check the sensor at the rear of the fuser. Sometimes sensor gets stuck.
Posted on Aug 18, 2008
ikechinedu
  • 184 Answers
SOURCE: squeaks and squeals when printing
since you bought it, has it been making this noise? if your answer is yes, then you don't have to do anything. if your answer is no, then you may have to get a machine lubricant and apply a little at the wheels on both ends of the printer. but you have to open it and take off the top cover. the screws are at the bottom of the printer.
Posted on May 28, 2009
HyeProfile
  • 35 Answers
SOURCE: Paper is torn at fuser area of Dell 1125 and cannot remove
Please double check if all doors, including the paper tray cover, are firmly (repeat FIRMLY !) closed. Seemingly all such are designed as precautionary measures for safe operation.
Posted on Aug 06, 2009
  • 35 Answers
SOURCE: The exit roller at the top of the printer is broken.
Hey that shaft kis called print header
Posted on Sep 18, 2009
Testimonial: "It definitely helps to know the correct name of the part. Thanks!"
  • 3 Answers
SOURCE: Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Posted on Oct 18, 2010
Close door or replace cartridge message won't go away
Replace the imaging drum and reset the life counter on Dell ...
www.dell.com/support/article/us/en/19/SLN142828/EN
DellOct 31, 2014 - Obtain replacement part; Fit replacement part; Reset life counter ...counter on Dell 1700, 1710, 1720, 2230, 2330, 2350, 3330 and 3335 laser printers. ...toner low and error lights, 23xx and 33xx will display the message Replace PC Kit. ...Fit the assembled toner and drum to the printer, close the front door.Missing: 5210n ‎persistent
34 Short Paper Error on Dell 5210n, 5310n Printers ' Dell US
www.dell.com/support/article/us/en/19/SLN133464
DellMay 10, 2013 - If the pegs do not change position, the gray paper size guide may have become separated ... On the left side of the inside of the printer, under where thecartridge goes, there are two white ... Close the upper and lower doors.Missing: laser ‎message ‎persistent
Dell Printer -- Feeder Problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/29793
Aug 28, 2008 - I am having trouble with my Dell 1700 laser printer. ..... the printer jams in the middle, I get the message, but opening and closing the front door will allow the..... I replaced the cartridge just in case,(the tape had been removed!) ...
Jan 08, 2016 | Dell 5210n Laser Printer
How to fix a Dell 5210N 900 RIP Error?
Replace printhead. If Dell can't be found or is cost prohibitive, use a refurb/reconditioned Lexmark T640 series printhead.
Aug 26, 2014 | Dell 5210n Laser Printer
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
Loud squeaking noise when you start up the dryer could it be a bearing dull squeak not high pitched a little bit of a grind sound
It does sound like a bearing or at least a lack of lubrication. But it could also be belt slippage if it only happens at the start. If it is the bearing it would be continuous and slowly get louder and louder.
Jun 18, 2011 | Whirlpool LER7646E Dryer
Paper from tray 2 starts to load then you here a high pitch squeak then paper jams and gives error code 241.09. Pull paper out of bottom tray reinsert paper then is fine till it jams again. Any thoughts.
If its some thing that just started, then you may want tocheck if you are using a new paper manufacturer. Sometimes frequent jams arecaused by thin paper.
Mar 02, 2011 | Dell 5210n Laser Printer
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
What does this error message mean: "917.00 service transfer roll"
The transfer roller is missing, not touching the drum, poor contact to the transfer high voltage or transfer high voltage shorted.
The trasfer roller is below the drum. Its bearings are on springs to press the paper against the drum. The drum rotates it by gears at one end. One of the bearings have electrical contact with the spring and the spring is connected to the DC controller. The transfer roller receives high voltage that attracts the toner from the drum. It's current is measured and when it's not within specifications the error occures.
Aug 05, 2010 | Dell 5210n Laser Printer
Garbage text from Dell 5210n
Try downloading and installing the latest driver from: http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&os=WW1&osl=en&catid=&impid=&SystemID=PRN_LSR_W5210
Besure to select your correct Operating System, and install any Patches and Updates available as well.
Jan 08, 2010 | Dell 5210n Laser Printer
Hey,
Oct 13, 2008 | Dell 5210n Laser Printer
Dell 5210n Laser Printer Logo
236 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
