Question about Epson Office Equipment & Supplies
My epson 284a shows an inverted image
The image projects inverted
Need to know how to invert a picture on a epson projector
You didn't give your model, but on the Epson I have (a PowerLite S1), the projection mode is controlled through the "Settings" menu. This may not be right for your model, but I'd think another Epson would be similar.
On mine, this is how it works:
1) Press "Menu" on the projector (or remote, which will work the same way)
2) Use the "V" (down arrow) to highlight "Setting"
3) Press "Enter" to select the "Setting" menu
4) Press "Enter" to select the "Screen" sub-menu
5) Down-arrow to "Projection" and press "Enter" to select it
6) Use the up- and down-arrows to highlight the arrangement you want from the choices offered:
  • "Front": normal use
  • "Front/Ceiling": image is vertically flipped
  • "Rear": image is horizontally flipped
  • "Rear/Ceiling": image is flipped both horizontally and vertically
7) Press "Enter" to select
8) Press "Menu" to exit the menus
I hope this works for you, or at least gives you a starting point. Good luck, and thanks for using Fixya!
Apr 23, 2011 | Computers & Internet
How do I flip the image on my Epson EMP 30 projector for ceiling mounting please?
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Feb 13, 2011 | Epson EMP 30 Multimedia Projector
How can I flip/invert the image for the powerlite 1716 projector for when it is ceiling mounted?
you must have the user manual, in there you will find the way to acces the menu and how to flip/invert the image.
Dec 01, 2010 | Epson PowerLite 1716 Projector
I can't get the image on my Macbook to project using a Mini display port to VGA adaptor to connect to an Epson projector. It only projects the screen saver background image...any suggestions?
Go to system preferences and then displays, there will be a check box indicating to activate video mirroring. Click on the check box and what will show is what is showing on the laptop. Hope this helps.
Sep 15, 2010 | Apple MacBook Pro Notebook
Image is projected inverted
This is the Manual http://www.projectorcentral.com/pdf/projector_manual_2869.pdf
Your projector is setup for use on the ceiling, and must be reversed.
Please "set the "Projection" command in the "Extended" to match the installation method.
Consult the manual for further assistance.
RTFM
Oct 12, 2009 | Epson PowerLite S3 Multimedia Projector
Lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Blue dots in the middle of the screen
The image processor must be getting old and worn out. Call Epson or go onto their website and see if it is  a dDIY project or if you will ned to send it in.
Apr 27, 2008 | Epson EMP S1 Multimedia Projector
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
