Question about Kenmore Elite HE4 Electric Dryer
How do i replace the dryer door handle on a Kenmore He4 super capacity electric dryer
I have a new handle, but would like step by step installation instructions
  • 126 Answers
SOURCE: Help with Dryer Seal Installation
check at sears parts department they can brig it up on the cnnputer for you
Posted on Dec 13, 2007
  • 14 Answers
SOURCE: Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Posted on Jan 20, 2009
Maytag317
  • 1136 Answers
SOURCE: Broken door handle
Hi, there should be two screws holding the handle. I looked up my suppliers and this would need to be ordered. The cost is between 21 and 29 dollars, depending on color.
Part#8559750 Graphite color or P#8559751 Black
If I can assist you further, please let me know. I can order the part.
Thanks
Vic
Posted on May 15, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore Elite HE4 dryer Model 100.95091401: I need
No seal. Take apart what you need to to replace the handle. Eric
Posted on Sep 12, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
Posted on Dec 28, 2010
My kenmore elite turbo super capacity drier will not dry.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][]
Sep 11, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer......Starts, runs and drys but has a REALLY loud squeaking sound
Please rate me
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore HE dryer door handle has cracked. How
Carefully remove the door from the dryer by removing the screws from the hinges and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
Searspartsdirect.com has some excellent exploded view diagrams that you can work from as well.
If you have questions, please let me know. I hope this helps you.
Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
He3 door handle repair
Carefully remove the door from the front of the dryer and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
Jul 21, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Broken door handle
Thanks
Vic
May 15, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer door handle
if you replace handle plastic door frame will need to be removed to access screws in handle remove the phillips head screws on inside.. front panel will pop off ..glue will not last very long but may get you by
Sep 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dec 12, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite smartheat9 model110.85862400
If i remember correctlysix screws on inside of door then the plastic frame comes off and two screws to take off door handle that should set u straight its the six small screws
Jun 02, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
154 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
