Hi. my problem is my router belkin g+ mimo cant detect the internet from my speedstream 4200 modem. i cant continue installing my belkin router because it cant detect internet connection.
please help.
Nothing seems to work. Had Belkin walk me through the setup. Now it won't even take the modem log in and password.Nothing seems to work. Had Belkin walk me through the setup. Now it won't even take the modem log in and password.
You can't post conmments that contain an email address.
Did you restart your computer? If so, I'd power down everything (modem, router and computer) and restart them in that order - modem, router, computer. My guess is that the router and computer addresses are not in sync.
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
