Question about Sony VAIO GRX580 Notebook
Hard drive location on Sony Vaio GRX580
Looking at keyboard where is hard drive located inside case?
  • 101 Answers
Top left next to fan
Posted on Jan 25, 2009
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Replacing hard drive
Well first of all does it have a Hard Drive or what they call the Solid State Drive (SSD) which looks like a wireless card or some type of circuit board?
Next thing is where is the drive located, no matter which type, where is it? On most systems the drive is on the bottom of the laptop, so all you have to do is remove the screws from the cover that houses the drive. Normally the cover will have the icon of 3 circular discs on it.
Sometimes the drive, no matter which type, will be located under the plamrest or keyboard, when means you have to take the unit apart to get to it.
OK, you're in luck.. I checked your manual and it says you have a 60GB SATA Hard Drive, but it did not say where it was located.
May 15, 2012 | Computers & Internet
Anyone know how to get to the hard drive in an old Sony PCG-F309?
LOL, the hard drive is probably located under the Keyboard or the palmrest. Sony was known for putting it under the keyboard or palmrest on older models.
Mar 07, 2012 | Sony VAIO GRX770 (PCG-GRX770) PC Notebook
How do you remove a hard drive on a Sony Vaio VGC-V617G? Thank you
The hard drive is located in the rear of the base. Remove the black plastic cover. Just look for the black screws holding it in then pull it back and up. The hard drive is held in place by four screws on the back side. Some components in this PC are for laptops however the hard drive is a standard PC size and connections.
May 25, 2011 | Sony VAIO VGC-V617G PC Desktop
I'm trying to open the case on my Sony Vaio VGC-LS21N integrated desktop computer, to replace the hard drive. Any ideas how to get it open and/or where the HDD is located inside the case?
Hi! You may download the Manual HERE and see how you can take out the hard drive out from the tower. Please be cautious while taking out the harddrive to avoid any incident.
May 12, 2010 | Sony VAIO VGC-LS21N PC Desktop
Location of the hard drive
Turn the desktop round so the back of it is facing you.
Remove the screws that are on the bottom left and right, and in the top middle and remove the outer casing by sliding the case towards you.
Once the outer cover is removed face the case so you can see the motherboard.
The hard drive is located behind the front panel of the case underneath the CD/DVD drives.
It should be laid on its side with cables coming from it.
As far as i know the hard drive bay will just slide out but there may be holding screws.
Regards.
Sep 17, 2009 | Sony VAIO PCV-RS312V PC Desktop
Sony vaio vgn-TX750P how to open the case to swap the hard drive
here you go mate i found u this coz i know how much of a pain in the arse sony vaio's are :
http://laptoplogic.com/resources/detail.php?id=43
GOOD LUCK LADS!
Aug 08, 2009 | Computers & Internet
Replacing Hard Drive in a Sony VAIO SZ330P/B
Turn your Vaio upside down and look for an easy access panel or release lever to remove the hard drive carriage. You will probably need a small Philip's screw driver to remove the carriage, but I don't think you need to remove the keyboard.
Aug 10, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Vaio VGN-TXN25N, need to remove hard drive
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Apr 23, 2008 | Sony VAIO VGN-TXN25N/B PC Notebook
Removing the hard drive to a Sony VAIO VGN-S660PNotebook?
On this line of Sony models replacing the hard drive is a pain because the computer must be taken completely apart to get to the hard drive. It is located under the palm rest. I looked up the Sony manual for this model and it does not show how to replace the hard drive -- meaning it should only be done by a trained tech.
You'll have to remove all the screws from the bottom and underneath the keyboard. Carefully detach the keyboard and set it aside. Once all the screws are remove from the laptop you should be able to separate the top of the casing from the bottom, this usually requires a small amount of force but too much force will crack the plastic! Underneath you will find the hard drive cage.
Also, some laptop vendors like to pull the 'hidden screw' trick! There may be a screw underneath the CD-rom drive so that may have to be removed or under some of the rubber feat on the laptop.
I couldn't find a photos or manuals that show how to do this, but these guys say they have a manual for a small fee. http://www.9manuals.com/Vaio2.htm
They want $5.99 for the manual but that is much cheaper than paying a technician to do it for you.
Good luck and be careful!
Nov 13, 2007 | Sony VAIO® VGN-S660P/B PC Notebook
Sony VAIO GRX580 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
