Question about Water Heaters
I need osaka gas english model of osaka heater 140-8033
2 Suggested Answers
in9876388918
  • 170 Answers
SOURCE: osaka gas heater manual
DOWNLOAD LINK
http://www.dl4all.com/aka/tag/osaka+gas+fan+heater+user+manual.html
OR
http://www.osakagas.co.jp/indexe.html
Posted on Jan 24, 2012
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
How do I convert my rheem water heater from lp to natural gas model#21vp40-1p
Call Rheem
Generally the company does not support changing type of gas since propane burns much hotter and has more pressure than natural gas.
You need different gas control valve, and need cast iron burner and orifice than matches that specific gas control valve.
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
http://waterheatertimer.org/Water-heater-manufacturers.html
Gene
Sep 14, 2014 | Water Heaters
What do I have to do to drain and disconnect GG40T6A model
1) Copy following link for installing new gas water heater, and use steps to move water heater, and then re-install.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Don't forget to tape plastic bag over disconnected gas connections to keep from getting dirty.
Dirt in the gas line, or on the threads can cause gas control valve to malfunction.
Mar 08, 2013 | Water Heaters
Rheem water heater flashes seven times ,it is in lock out mode
You have Honeywell electronic gas control valve, and error code is 7 flashes.
Probably you have power vent model.
One manual from different company says: "Reset gas control using on-off button on front of control, replace flammable vapor sensor, replace gas control thermostat.
But with Rheem you also need specific steps: Remove gas burner and look for broken glass vial, and then blow out arrestor screen air intake using compressed air, clean burner parts, check for unobstructed venting, you will need new glass vial from Rheem depending on year and model number of water heater that appears on label on side of unit, or they may not have a repair kit for that model, and you might need a new gas control valve depending on model and how extensive problem was
You have Rheem water heater.http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 28, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Osaka gas heater manual
DOWNLOAD LINK
OR
Jan 24, 2012 | Water Heaters
I would like to know the electrical requirements.( voltage and amperage) Does it plug in or is it hard wired? If the power goes out is the hot water also out? thankyou
Are you asking about tankless gas or tankless electric?
You posted under Tankless gas water heater: gas type tankless plugs into standard 120Volt household outlet to power circuit board. You need larger gas line than used for tank-type gas water heater.
If you are asking about volt and amp draw of Tankless electric, then that depends on specific model number.
For example, if each tankless element draws 3500Watts, and unit has 3 elements, you will need 3 additional 20 amp 240Volt circuit breakers. Volts x amps = watts. 3500 watts divided by 240Volts = 14.58 amps. At full blast, this unit would draw 43.75 amps and will cost more to operate yearly than tank-type electric water heater. If unit has 4500 watts elements, then it will draw 56 amps at full blast, and use a good percentage of household power.
Tankless water heaters have no hot water in power outage. This is true for gas and electric models.
Additional resources:
http://waterheatertimer.org/images/Compare-water-heater-parts-650.jpg
http://waterheatertimer.org/pro-n-con.html
http://waterheatertimer.org/pdf/Bradford-White-on-demand-tankless-service-manual.pdf
Aug 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
I have a 75 gal. powervent model #42vp75fw. the vapor sensor shut it down and i do not know how to reset it. please help. thank you
I answer questions for free.
My job is to provide resources that help you for free.
1) That being said, my research into FVIRs says you need a plumber when the FVIR trips.
2) The use-and-care manual for your model also says call a technician.
3) Buying replacement parts through a plumber is true for all water heaters except the Bradford White which has a resettable FVIR. BW is the only company with a re-settable FVIR, however the water heater market changes daily.
4) If the FVIR shorted and shut down the water heater, it probably saved a fire and maybe saved a life.
The following site says to call Rheem, who will tell you to call a local plumber.
http://www.terrylove.com/forums/showthread.php?2520-Broke-Rheem-FVIR-waterheater-Please-help
The Rheem lineup of gas water heaters shows you have a 75 gallon tall heater:
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
The spec sheet for your model
http://globalimageserver.com/fetchDocument.aspx?id=e3d293b7-bedf-4d9f-bf0f-d85b2d8bda5f
The use and care manual has troubleshooting section > it says the combustion shut-off has to be inspected by qualified technician
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
To get opinions from professional plumbers in the field:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/fvir-issues.html
Nov 05, 2010 | Rheem Water Heaters
Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Feb 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
53 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
