Question about JVC AV-56WP30 56" Rear Projection Television
Tv screen waves and is double
My jvc tv model av-56wp30 has a big wavy line across the top and is double visioned. The screen seemed to be getting a little darker over the years too. is this a problem i can fix my self?
  • 3 more comments
  • Anonymous Jan 13, 2009
    how much will it cost
  • nicholas petropoulos Feb 09, 2009
    Changed the parts my self and it works great, It was easy thanks.
  • hot66ford Feb 15, 2009
    tv screen waves and is double problem and colors won't line up
  • sydro Mar 21, 2009
    my jvc tv model av-56wp30 has a big wavy line across the top and is double visioned. The screen seemed to be getting a little darker over the years too. is this a problem i can fix my self?
  • Anonymous Apr 23, 2009
    the color seems to be going on my screen but more importantly the scree is showing duplicate/triple.
  • 87 Answers
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Jul 13, 2007
Hi i have a jvc tv model av-56wp30 it has a red line in the corner of the tv what seem to be the problem and will it cost me alot of money to fix?
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,B,G mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board it is dead.The tv convergence board,must require repalcing 2 STK convergence ICS and some or all of it resistors too.The tv convergence board is fix,will solved ur tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP30 56" Rear Projection...
My jvc tv model av-56wp30 has a big way line across the top
You have a CRT TV
CRT's get dim with AGE. This is normal.
Your TV is getting old.
NO fix. Get a new TV
Mar 24, 2009 | JVC AV-56WP30 56" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
My 56'' jvc av56wp30 tv screen is doubled only twords top o screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 19, 2008 | JVC AV-56WP30 56" Rear Projection...
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Jvc AV-56wp30
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | JVC AV-56WP30 56" Rear Projection...
Jvc av56wp74 rear projection tv
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc model av-56wp74
Needs convergence IC's replaced..........T.
Oct 06, 2007 | JVC AV-27850 27" TV
Jvc 56wp30
1st guess is bad convergence ic-either IC804 or IC805. Both are part #STK392-110. May be bad connections in convergence circuit, or open resistor(s) As for too much green, not sure, shouldn't be because of convergenece circuit, possibly green CRT screen voltage needs adjustment.
Dec 22, 2006 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
855 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
