Question about Oase Pondovac Classic formerly Pond-O-Matic
Oase 7003pv pondovac wont start
It has a remote control, does it work solely off that? Would of thought u could use with or without, cant see a float sw on the unit head
We have a new pink steamglide iron Model No18160. The sole has a stain which I cannot clean. The instructions recommend using vinagar which I tried and which did not help. Can you help advice?
There are many products on the market which can be used to clean stubborn stains from the iron sole.
However, for realy stubborn problems I would use very fine sandpaper with a grit of aproximately 1200.
With a fair amount of rubbing or sanding it should be possible to remove any stain or mark from the bottom of the iron & provided you use a very fine sandpaper it wont leave any scratches.
Best wishes,
Graeme.
Mar 22, 2011 | Vacuums
My Dyson DC07 has recently been service and was making a clattering noise and very hard to push. We have taken it back and he has changed the clutch mechanism under the base which has solved the...
On the sole plate you should have 5 little wheels, these are prone to jamming after a while. You should make sure these are not jammed in anyway.
You can release these with a screwdriver, but be careful not to prize too hard as you may damage the sole plate.
Take all the wee wheels out and spray them and the sole plate with wd40 and then replace.
This should help
Mar 06, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When i set the floor setting to carpet, it makes a nasty rattling noise. doesn't do it on bare floor setting
There is one major difference between the hard floor setting and the carpet setting - the brushbar doesn't spin on the hard floor setting. Hopefully this is a simple problem - the rattling noise suggests there may be something trapped behind the brush rollers. You can inspect this by removing the sole plate from the vacuum. Doing this may allow any trapped objects to fall out without need for any further inspection:
To remove the sole plate:
1. Lie the dyson on it's side so you can access the underside or sit on a chair, turn the vacuum upside down and hold it between your knees.
2. Using a coin or a large flat-bladed screwdriver undo the two yellow fasteners on either side of the "sole plate" which covers the brush rollers.
3. Pivot the back edge of the sole plate upwards and remove it
Any loose debris can now be easily removed, While the sole plate is removed, it is a good opportunity to inspect the brushes and remove anything else that may be stuck to it.
Replacing the sole plate is the exact reverse of the removal process. Before replacing the sole plate, ensure that the brush bar is correctly and fully inserted.
There are other possible reason for the rattling noise, but your description leads me to believe that this should cure the fault. Inspect the brushbar first and then post back if you need further assistance.
Regards,
BElectric
Dec 15, 2010 | Dyson DC33 Bagged Upright Vacuum
The motor is working but brush not spinning
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC07, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Oct 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hopw to fit new belt
If, after removing the cover, the other belt is okay, if your brush bar isn't turning then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07.
Oct 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson vacum beater bar does not work
DC14 have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC07 (the DC14 is very similar to the DC07), but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Oct 04, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
How do i change the fan belt on a dyson dc07i
Sep 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I need more suction. The Head is too high on my carpet.
Hi.
A slitght adjustment can be made by either screwing on short transparant internal hose on top of floor head tighter or undoing it turn.
Do this on A table as you need to get down to be able to view sole pate movement
Each time you adjust hose stand vac up on the table & pull handle back as if cleaning carpet you must not push head of vac down on the table.
Now look at sole plate usually when they are wrong the sole plate bottom back end tilts up lifting brush from carpet.
Now tap front of head down if sole plate springs back up lifting brush up again adjust hose a bit more.
What you are trying to do is get sole plate as horizontal as you can.
If you really cant get it to pick up dirt any better try fitting new hose they are more sprigier from new,
http://dysonmanuals.llc.nu/
Jan 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bar on my Dyson wont turn
If its a standard DC07 you can check the belt by loosening the pegs on the sole plate with a coin. Once this is taken off you can inspect the belt.
If you have an All Floors model/Green DC07 then the drive belt is a sealed unit which cannot be replaced and must be fixed by an engineer.
Dec 29, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oase Pondovac Classic formerly Pond-O-Matic Logo
331 people viewed this question
Top Oase Vacuums Experts
Are you an Oase Vacuum Expert? Answer questions, earn points and help others
