Question about Delphi Fuel Pump Chevrolet Express 1500 2002 2001 2000 99 98 2500 Fg0099
Why does my gas gauge stop in middle
My van stopped running but the gas meter stayed half way
    Genius:
  • 1,003 Answers
The float could be stuck in the gas tank
Posted on Jan 22, 2013
My temperature guage stays in the middle, is this ok?
Yes, the temperature gauge should normally stop in the middle, between the cold and hot points on the gauge. When the engine is cold the thermostat will be closed and will keep recirculating the coolant in the engine block until it warms up sufficiently. Then the temperature of the warm coolant will cause the thermostat to open the channel to the radiator to get rid of excess heat, which should stop the coolant from over heating. So the effect of the thermostat keeps the coolant at a fairly stable temperature. When the coolant runs low, it can't transfer enough heat to the radiator and the coolant and engine then over heats. Watch for radiator leaks under your car after you have been driving it. If the coolant goes low again fairly quickly you could have a leak in a hose or the radiator itself.
Apr 19, 2013 | 2003 Mazda Protege
Dash gas gauge stops showing proper gas level once it hits half a tank. Then gauge will fluctuate between empty (light will come on), full and anywhere in between but seems fine from full tank to half
If the trouble with the gauge started after you worked on it then you likely damaged or created a restriction to the movement of the sending unit. You will have to remove the tank and double-check your work.
Mar 01, 2013 | 2000 Buick LeSabre
1999 dodge caravan gauges are all mest up
Could be different problems.
The cluster issue could be a problem in the printed circuit board inside the cluster.
The cooling fan problem could be low coolant, a blown fuse, a faulty temp sensor, fan motor, or relay.
Jul 07, 2012 | 1999 Dodge Caravan
2003 H2 gas and battery gauge just stopped working. Is there a fuse somewhere?
if it was a fuse they would all stop working as it is a electronic cluster. most likely a gauge fault but you might run down the wiring with a volt meter, where the voltage stops is where the issue is. also you might verify you fuel sender is working and check voltage to battery while running
Mar 19, 2012 | Hummer H2 Cars & Trucks
I have a 2000 buick Le Sabre. gas gauge does not work properly. i filled the tank and the gas gauge reads full. and it works properly past half. then it starts flucturating. i disconnected the gas gauge...
There are three possibilities. The gauge could be defective. The instrument panel voltage regulator could be bad or not grounded or (most expensive) it might be the sending unit.
Mar 11, 2011 | 2000 Buick LeSabre
Instrument panel.
There is a bad connection at the cluster,remove the cluster,and check the plug in to the cluster,it is a bad connection.Also check the alternator to make sure there is enough volts present,with everything on,lights,ac/heater,on high,it should read at the battery,while engine running,13.65 volts,to 14.25 volts,if it is any lower,replace the alternator.
Jan 24, 2010 | 2003 Chevrolet Cavalier
1991 Honda Accord Ex. When my gas gauge reads
your gas pump is going bad the sensor is nt responsive to to gas in the pump
Jul 15, 2009 | 1991 Honda Accord
1999 monte carlo LS won't stay running
yes it the fuel pump . the float is getting stuck
Dec 13, 2008 | 1999 Chevrolet Monte Carlo
Seems like it's not getting enough gas
It could be your fuel pump with your car not running right, the gas gauge thing i have no clue maybe the sensor inside the tank is messed up. or it could just be your fuel filter not doing its job. Htere are a few things it could be I would say Fuel Filter, Pump and maybe a vacume (spelling) problem, I would need to be there and hear it running or drive it to really figure out what it is
Oct 21, 2008 | 1998 GMC Safari
Delphi Fuel Pump Chevrolet Express 1500 2002 2001 2000 99 98 2500 Fg0099 Logo
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
