Question about Ovens
I am trying to connect the circuit board I need help!!! I need a wiring diagram OR A PICTURE OF the circuit board BEFORE THE WIRES ARE REMOVED!!! Please pleas help
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 15 Answers
Can you give more info'??
Posted on Jan 17, 2013
3 Suggested Answers
  • 10865 Answers
SOURCE: i need wiring diagram for
hello. go to searspartsdirect.com
enter the model number and you will get an entire set of schematics to review for free. Joe
Posted on Oct 13, 2010
SOURCE: electrical connections on indesit cooker
looking forwir diagram for top grillelement 720ef
Posted on Dec 04, 2010
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Jenn air sve47600w
with wiring diagram check to see if any power to circuit board. check any limit switches in line in oven circuit. then check the following.sounds like a circuit board problem. turn power off for a minute then try again. also with power off unplug all connections to board and plug back in. if still problem replace electronic oven control board.
Nov 16, 2013 | Ovens
Maytag oven model mew5530ddb touchpad keys 1,2,8 and clock buttons do not work.
HI. I recommend to inspect the connecting wires at the control sector for loose, or cut connections. If the connecting cables are connected well, and are not loose, simply have the touch pad, or control board replaced, asap. I have posted a link to an exploded diagram of the control sector. Use this diagram to help disassemble the control sector for the inspection.
Click Here To Access Diagram.
Mar 01, 2010 | Ovens
No power
you need to check the main circuit breaker in the house and make sure it is not tripped.
the check the main wiring harness connected to the back and insure all your wires are conneced properly.if you have had any kind of power surge the your main control board may have suffered a fatal short.you need to look at the control board and look for any discoloration on the boards circuits.
Feb 01, 2010 | Frigidaire 27 in. Electric Double...
1 or 2 circuits to create 2 phase?
How to explain this? your new drop in unit will require a 220v circuit capable of a specified amount of amps. Typically 40, 50 or 60. Should be noted in the manual and on the unit itself. If your original oven and cooktop were electric, then each one was probably hooked up to a 220v circuit. The problem is figuring out how many amps were supplied for each. The simplest way is the go to the panel and find the breaker for the old oven and cooktop and read the numbers (or amps) on the on/off switch. If either breaker has a number the same or greater then the drop in unit says it requires, then your all set. If the drop in unit says it requires 52amps and one of the breakers says 60 on it, your fine. If the drop in unit says it requires 44amps and the breakers are 30 or 40, then you got a problem. Usually a breaker is installed that is the maximum amps allowed for the size (thickness) of the wire connected to it. You CANNOT connected a 50a breaker to wire only rated for 40a. Note the size difference of wire connected to a 20a breaker with wire connected to 40a breaker. If the drop in unit requires more amps then the original units used, then a larger wire will need to be ran from the panel to the drop in unit (Not cheap). Now if the original oven used a 30a and the original cooktop used a 30a, then its possible ( 80% of electricians wouldn't do it because of liability problems) to use both wires together to create 60amps, but both wires (actually a total of 6 wires, 2-120v wires and 1 ground wire from each outlet) would need to be in the same outlet box for the drop in unit connection.. I could (and probably should) try to explain more, but I'de probably just confuse you more. GOOD LUCK!
Nov 28, 2009 | GE Profile JT952 Electric Double Oven
Cooling fan does not come on at all...
Hi ,I posted this problem as well (ROYP75) I fixed the problem by replacing the printed circuit board(this amongst other things controls the fan speed).If you can remove and replace self tapping screws and replace wires like for like on the circuit board you can do this.Isolate from gas and electric, remove oven back taking care with fan wires, wires connected to circuit board and fan connected to oven back once removed you will see circuit board and from their it's just a case of swapping parts .circuit board was purchased from espares .co.uk part no es660722 hope you find this helpful
Oct 06, 2008 | New World G60m Gas Single Oven
One more question
The electronic control board will have to be replaced. You can search online or call Sears (they can order just about any type of part for any type of product for you) with a model and serial number. Generally, the electronic control board is not that difficult to replace.
Jun 09, 2008 | Ovens
Electrical connections on indesit cooker
Is it just a 2 wire connection element?
Feb 29, 2008 | Ovens
Oven mystery....need the best GURU or Wiz....CHALLENGE! Please help!!!
was the thermistor that connects to the heat board replaced?this is the bulb inside the oven that monitors the heat,it should have 2 wires going to the board.try wiggling these wires and see if it starts to heat,if so the thermistor is bad.
Jan 06, 2008 | GE Monogram® ZET3038 Dual Single Oven
Ovens Logo
43 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
