Question about Price Pfister 01-81BC Savannah 3 Handle Tub/Shower, Bell Shower Head With B
3 handle shower - handles tap/ block each other
When you adjust the water temperature the diverted and hot and cold handles hit each other. Is there a way to adjust the handle so they never meet/tap each other?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
It sounds like you have the wrong handles for this faucet assembly. Did you recently purchase new handles?
Posted on Jan 22, 2013
SOURCE: shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Posted on Jan 30, 2009
  • 19 Answers
SOURCE: price pfister single handle shower faucet
home depot has all the parts for price fister
Posted on Feb 04, 2009
  • 30 Answers
SOURCE: I have a Price Pfister Model no. 808 DK00 single
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Posted on Sep 18, 2009
SOURCE: I have an 11 year old, single handle shower
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Posted on Feb 08, 2010
Testimonial: "I followed the directions and it became an easy fix!! Thanks"
bloues
  • 56 Answers
SOURCE: The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Posted on Jul 20, 2010
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
No Hot water
Now there could be many reasons why this is happening. 1 the diverter may be assembled incorrectly. 2 the diverter/cartridge may be defective. 3 the plumber may have used to much solder, filling the pipe thus blocking the flow. 4 There is a shut off valve somewhere that's closed.
Do you have a home warranty? If so I would suggest calling the builder and inform them of the problem. Any respectable builder gives a warranty, I believe in most states its mandatory. This should be covered. Just a heads up, this could involve some holes being opened in the walls, ceilings, and floors in more than one place.
Jun 06, 2010 | Moen & One Handle Tub & Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
No cold water
Behind the handle there is a dial to adjust water temp cold and hot you can remove it and replace it a 1/4 turn til you can get both cold and hot. It is a anti scald it may have been put in wrong.
Make sure the cold water line is not blocked coming to valve and is open .
Mar 15, 2010 | Danze & Single Handle Tub And Shower...
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Price Pfister 01-81BC Savannah 3 Handle Tub/Shower, Bell Shower Head With B Logo
Top Price Pfister Home Experts
Mike
Tim Whalen
Donni Steen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
