Question about Toto Aquia II Dual Flush Toilet
Glacier bay toilet tank doesn't refill - Toto Aquia II Dual Flush Toilet
3 Suggested Answers
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
I need a repair manual for a Glacier Bay Toilet Model#N23167
Hey Pam.
What is your toilet not doing?..
please reply to me on here
Jul 18, 2017 | Glacier Bay Home
Where can I get a replacement handle/flush lever for a 2006 Glacier Bay 1.6 gallon toilet?
Glacier Bay Toilets are made in China by "various manufacturers" a local plumbing parts supplier is your best bet.
Jan 11, 2016 | Home
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
Glacier bay instructions
If it has a fluid-master assembly, there's a metal bar on the side of the float with a small metal adjusting tab on it, squeeze the tab together and raise or lower it on the bar to change the float setting.
Aug 23, 2014 | Home
Water won't stop running in glacier bay n2316 toilet
Replacement parts you can find on amazon. take a look here Amazon com glacier bay toilet parts Hope this was helpful. cheers
Jul 03, 2012 | Home
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 | Home
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Jan 28, 2011 | Home
Glacier bay gal toilet.
Does the tank lid have a seal on it to keep water from coming out?
May 30, 2010 | Home
Toto Aquia II Dual Flush Toilet Logo
44 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
