Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
  • Konica Minolta Master
  • 1,294 Answers
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Posted on Feb 01, 2013
2 Suggested Answers
  • 158 Answers
SOURCE: error code c-d369
this is a nvram error code most likely the nvram board will have to be replaced and konica minolta has made the procedure for obtaining this board very hard so i am sure the copier repair company you are using is aware of the cause but ti is going to take some time to get the part that is needed to fix the problem. the reason for the procedure and paper work to get this board is all the counts and settings for the machine is stored on this board and some lets just say dishonest copier repair companys could but a used 250 with a lot of copies on it and replace this board then sell it as a new machine.
Posted on Nov 28, 2009
A/c will not switch to any settings (floor, vents, etc..) just blows out of top of dash. I did put a new battery in it after it sat for a month.
Sounds like you need to recalibrate the HVAC
Turn on the HVAC so that the blower motor is working. It doesn't matter what speed. Turn the key off. Pull the HVAC/ECAS fuse from the under hood fuse block. Wait a couple of minutes and reinstall the fuse.
Turn the key on but do not start. You should hear the HVAC changing modes. it will take 3-5 minutes to complete. Once you stop hearing it changing it should be reset. Turn the key off and start the vehicle. It should now work.
Sometimes it will take a couple of tries but eventually it will go unless it detects a fault. If it does it will go back to defrost until the fault is resolved.
Jul 27, 2011 | 2004 Chevrolet Suburban
Tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
on Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Video card or driver doesn't support the required fixed-function texture blend operations. DirectX 7 rendering path will not be available. Video card or driver doesn't support direction lights in...
Hello, the problem seem to be related to the video card you're currently using, See if you have an integrated video card: a hint to find out is to see behind your computer if the monitor connection is on a side of the back panel is probable you have an incompatible integrated video system, you can solve this problem by buying and installing a compatible video card as any Nvidia or ATI card, Call an IT professional and ask for some advice on what card you should buy and install to make these problems disappear, also ask him/her to install it for you.
Have a nice day, and If you have any other questions you can come back and reply.
PD: If you still want to buy and install it yourself ask me again and I'll help you.
Jun 03, 2011 | Microsoft Windows XP Professional
I can't make my canon mp460 do anything. little used i've just taken it out of it's box again and changed the ink cartridges but nothing. error 5010 showing.
hi
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request."
or
go to following link you will have more solution
http://www.subnixus.com/error-codes/error-5010.html
May 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp600 pixma; it just started doing this when I tried to print; now I can't seem to be able to do anything with it. I assumed it was due to one of the ink cartridges being out and so I replaced...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Printer displays 510 error code. I need the local service center address
HI
Got this from usa canon.com website click here and type error code in the search box
a list of the error codes will be displayed and you can then click on the relevant one.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
Jun 20, 2010 | Office Equipment & Supplies
We want error problem ofter switching blinking red print key without warming and function 4 delate error not any function by copier
First you need to let us know what the error code is displayed on the display screen. With that there is a starting spot, then will be able to move closer to solving the problem...
Oct 10, 2009 | Canon NP 6050 Copier
Panasonic workio 3000 error code E04-01
Your FUSER is not warming up. It needs to be replaced.
Jun 29, 2009 | Panasonic WORKiO DP-3000E Printer
Canon mp830 error code 5010
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
Nov 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
112 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
