Question about OKI MICROLINE 590 Matrix Printer
On the cell dyn 3700, unable to print the entire data table for calibration or for reagent log
Is it good idea to repair sql file?
Bulk Logged will not help you in this situation. Your transaction log is growing because you are performing large transactions. In simple mode, the log is truncated after a checkpoint.
Check these site: http://www.sql.recoverytoolbox.com/ & download demo Recovery Toolbox for SQL Server.
Depending on how you are loading your data, you may need to break it up into smaller chunks. Make sure you are not loading all the data in one large transaction.
Read more: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/380-is-it-good-idea-to-change-simple-recover-model-into-bulk-logged-on-etl-system
Nov 06, 2014 | Microsoft SQL Server 2005 Standard Edition
Write down the equation for the formation of the complex trans-K[Cr(C2O4)2(H2O)2.3H2O from the reactants K2Cr2O7 and H2C2O4.2H2O.
limiting reactant:
The limiting reagent, or also called the "limiting reactant", is the chemical that determines how far the reaction will go before the chemical in question gets used up, causing the reaction to stop. The chemical of which there are fewer moles than the proportion requires is the limiting reagent.
Limiting reagent formula
There is a much simpler formula which can be used. However, you must first calculate the moles of both of the reagents in the reaction. Once the number of moles have been figured out, just simply fill in this equation (reagent 1 being the first reactant and 2 being the second):
When the answer to the formula is less than zero, reagent 1 is the excess reagent. When the answer is larger than zero, reagent 1 is the limiting reagent. The number shows how much in excess one reagent is from another. If the answer for the formula is zero, both reagents are perfectly balanced. The unit of an answer is in moles.
Oct 17, 2013 | InnerIntimates Vaginal Renewal Complex...
HI I have a Transcend hard drive and it formatted, all documents and pictures are all deleted, how can i get it back. Pls help thank-you
Hi jennielakato
It is not easy to recover files from a formatted hard drive, but it is not impossible. Data written onto a Hard Drive or other storage device is not deleted by formatting. Formatting is a BIOS instruction to the Operating System, defining areas on the write/read surface of the hard Drive to and from which the Operating System can and cannot write and read data. Any data written prior to formatting is still there, under the formatting, it's just that the Operating System is instructed to ignore it. Retrieving this lost data requires the Hard Drive to be removed and connected with a Hard Drive Dock, and External Hard Drive Enclosure or a USB to IDE/SATA Adapter Cable to a 2nd Computer with specialist Data Recovery software installed on it, such as:
NTFS Deleted File Recovery
(http://win.softpedia.com/dyn-search.php?search_term=Deleted+File+Recovery&x=7&y=11)
EasyRecovery Pro
http://win.softpedia.com/dyn-search.php?search_term=EasyRecovery+Pro&Submit=Search&license_filter=0&results_per_page=20&lastupd_filter=0&sort_field=0
Power data Recovery
http://win.softpedia.com/dyn-search.php?search_term=Power+data+Recovery&Submit=Search&license_filter=0&results_per_page=20&lastupd_filter=0&sort_field=0
GetDataback for NTFS
http://win.softpedia.com/dyn-search.php?search_term=GetDataback+for+NTFS&Submit=Search&license_filter=0&results_per_page=20&lastupd_filter=0&sort_field=0
Undelete Plus
http://win.softpedia.com/dyn-search.php?search_term=Undelete+Plus&Submit=Search&license_filter=0&results_per_page=20&lastupd_filter=0&sort_field=0
Active File Recovery
http://win.softpedia.com/dyn-search.php?search_term=Active+File+Recovery&Submit=Search&license_filter=0&results_per_page=20&lastupd_filter=0&sort_field=0
Since Data Recovery applications work by jigsaw-puzzling matching but dislocated File Fragments back together, it is more difficult to recover data if any new data has been written onto the Hard Drive after formatting. Since different Recovery applications use a variety of heuristic data matching algorithms, some more effective than others, it worthwhile trying a variety of different applications, if the lost data is important.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 19, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I am unable to see my call log in my nokia x3-00 cell phone, please assist me on the same
Your mobiles built-in memory card may be full. remove additional memory card if u have inserted, then delete the datas in the mobile bultin memory. then reinsert ur additional memory card.
Mar 14, 2011 | Nokia X3 Cell Phone
AutoCAD 2010 won't start after reinstall.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-2010-does-not-start.html
Issue:
When you try to start AutoCAD, you briefly see the splash screen and the program does not start.
Solution:
This behaviour can be caused by corrupted license information.
Please check if there are any errors listed in the ACD2010ENGAdlm.log file in the folder:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)
or
C:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
  1. Uninstall all installed 2010 products
  2. Delete the ADLM folder mentioned above, and
  3. Reinstall the products
Oct 14, 2010 | Autodesk AutoCAD 2010
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
Dyn dns config
you haft to log in to the routers settings and set it up in there.
go to 192.168.1.1
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
OKI MICROLINE  590 Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
