Clicks only when in wash or spin cycle
Will fill with water but hear a click noise in wash cycle and nothing when in spin cycle. I think clicking noise is the controls. I am not sure if the problem is on the control or the electric motor. I smelled something burnt when I checked the washer. The motor spins freely, belt and idler pulleys seem fine. I do not know what to check, how or replace on the controls.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Try the compasster like a white or sliver battaRIE looking thing with two wires
Posted on Jan 18, 2013
SOURCE: Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Posted on Apr 19, 2007
vest6
  • 196 Answers
SOURCE: Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Posted on Jan 08, 2008
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
  • 36 Answers
SOURCE: agitater does not spin
the transmission needs to be replaced
Posted on Jan 04, 2009
localwonder
  • 6784 Answers
SOURCE: no drain or spin cycle
Check the following to address the issue--
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 03, 2009
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Washer filled with water and then does nothing but make a clicking noise
If it's not spinning, the transmission is bad. If it's just not emptying the water, the pump is clogged or bad.
Unless you can replace the transmission yourself, it would be a better bargain to buy a new washer.
May 03, 2009 | Washing Machines
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Indesit WD11
is the drum turning round. is it draining at end cycle ? if the motor is spinning is it slow at start turning left then right after a time or does it just spin when its on spin cycle ? can you hear a clicking sound when it about to move or hear a clicking sound and nothing moves ? if you hear a clicking but nothing is moving it could be the switch on the main board has worn out, it could even be the motor but if it does a spin it could just be the switch on the main board. they soldered in on the board you can replace them if you have soldering skills or would like to learn.
Jun 22, 2017 | Indesit W 123 Front Load Washer
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Oct 21, 2007 | Bosch WFL 2063 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
