Question about HP LaserJet 3050 Printer
Vertical lines when printing on hp3050 laserjet
SOURCE: HP LaserJet 4 printing vertical lines all down and across page
sounds like your fuser assembly needs to be repaired. you can get the parts online fot about $40USD.
Posted on Mar 29, 2008
SOURCE: HP LASERJET 1018 PRINTING PROBLEM
try another toner cartridge, that should solve it, if not, it is the fuser and it's cheaper to buy a new printer
Posted on Mar 13, 2009
SOURCE: HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Posted on Mar 21, 2009
SOURCE: HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Posted on Apr 08, 2009
  • 81 Answers
SOURCE: black vertical lines on laserjet 4650 print out
I'd would put this fault down to the ITB ( image transfer Belt ) that sits at the front of the printer in front of the toner cartridges.This will wear with use and start to exhibit lines on the belt which can then transfer toner to the page
Posted on Oct 13, 2009
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
HP Laserjet 3052- Printing problem
Your printer's drum must be cleaned or replaced if damaged.
Aug 09, 2008 | LaserJet 3052 All-In-One Printer
I have a hp3050 laserjet . I can't seem to send
you need to install the full software solution, you can get it from www.hp.com, on newer operating systems, as Windows 7 this option is not available at all
Apr 06, 2010 | HP LaserJet 3050 All-In-One Printer
I am trying to send a Fax but keep getting a communications error
Vonage is a DIGITAL phone service. ALL fax machines are analog devices. You need a plain old telephone line.
Jul 22, 2009 | HP LaserJet 3050 Printer
Line on the sheet when I copy.
Most likely the scanner glass is dirty. You may have a very small speck on th scanner glass under the document feeder. When this happens a line will apear down the page that has been scanned/copied.
Even if you cannot see anything on the "****" Glass clean it anyway and check it from different angels of light and this should do the trick
Jul 07, 2009 | HP LaserJet 3050 All-In-One Printer
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Mar 20, 2009 | HP LaserJet IIIp Printer
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
HP LaserJet 3050 Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
