Question about Sony SA-WM250 Subwoofer
Regarding Sony SA-WM250 Subwoofer
Well i had this subwoofer for some time now, but never abused it, and it performs great, except the odd time when the bass will cut out..... then kick back in. Any ideas to what this may ? I checked my cords and connections, messed around with them a bit, and nothing happens to the bass, so thinking it must be something else, i am using a sony amplifier model STR-de597 hooked to the playstation 3, but im sure all my settings are correct. Any help would be great!!
  • Anonymous Apr 01, 2014
    I want to connect sansui subwoofer SW6000 to sony amp STR-DK5 is any problem there?
    Problem Solver:
  • 8 Answers
There is probably a bad solder joint or loose wire inside of the sub box. If you can, unplug the sub, take the screws out and remove the back to inspect the circuit board. A clean solder joint is pointed and shiny, with the solder evenly distributed in the hole. Also check to see if any plugs are loose. Plug in the audio input and then the power, but be very carefull not to touch anything inside the box while the cord is plugged in!! Play some bass at moderate volume so there is pretty constant sound. Now, take a screwdriver with an insulated handle and gently tap around on the connectors and circuit board. Tap a little harder if nothing happens, also tap in different areas to try to force the sound to cut out. You can try to locate where the bad connection may be by tapping lightly and zeroing in on the location. When and if you find the problem, you will need to solder the connection with a soldering iron. If you don't have a friend to help, try a local electronics store. Good luck!
Posted on Jul 13, 2007
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
I have a Sony sa-wm250 active sub there is power
Check the high pass low pass setting on your amp
Oct 19, 2014 | Car Audio & Video
There is no power to the subwoofer when its pluged in
hi; try to check the power cord and AC plug if still good condition, if ok.
open the back cover of you wooper using screw driver,search the fuse where AC cord was connected,
if you find the fuse check if it's blown. some wooper has varistor and thermistor for protection,
try to check if it has burn parts, you cen remove it and replace it by soldering iron, you can buy these parts at your local electronic store.
if you cannot do this soldering things, call a repair technician
thanks hope this help you,,,
Sep 05, 2011 | Sony SA-WM250 Subwoofer
Can i connect this straight to my sansung LED TV
If the tv has a coax sub output then yes.
Jan 11, 2010 | Sony SA-WM250 Subwoofer
Subwoofer plug broken?
Most likely the plug is ok but the level control for the subwoofer will need to be readjusted in the receiver, If the level cannot be raised making sure your source being used has subwoofer information, then there could be a problem in that circuit.
Jul 17, 2009 | Yamaha RX-V661 Receiver
I cant connect my subwoofer
welll if your handy with solder then you can just get the rca solderables from radioshack ans some speaker wire solder pos to pos and neg to neg and voila you got some patch cable just make sure that the outside neg- part of the rca matches the neg  lead you want-z
Feb 20, 2009 | Sony SA-WM250 Subwoofer
Terrible distortion from Sony Dav-x10 2.1 subwoofer
its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Nov 11, 2008 | Sony SA-W305 Subwoofer
SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Sep 25, 2008 | Sony SA-WM500 Subwoofer
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Jan 14, 2008 | Sony SA-WX90 Subwoofer
Sony SA-WM250 Subwoofer Logo
440 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
