Question about LG DLE2350 Electric Dryers
My lg DLE2350 dryer is making a high pitch beep and voice says low battery. what does this mean?
The dryer seems to work fine but in the middle of the night it started to make a high pitch beep and a voice says 'low battery' and the next couple words are inaudible. This happens every minute or two. Even when the breaker was switched off it still made this noise. What is it and how do i fix it?
    New Friend:
    Problem Solver:
  • 13 Answers
Ther is no battery in a dryer i think its your alarm clock
Posted on Jul 19, 2013
MNTECH
  • 1543 Answers
SOURCE: LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Posted on Jan 03, 2009
Testimonial: "YOU HIT THE NAIL ON THE HEAD WITH THIS SOLUTION. THANKS"
localwonder
  • 6784 Answers
SOURCE: LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Posted on Jun 01, 2009
SOURCE: Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Posted on Jul 25, 2009
MNTECH
  • 1543 Answers
SOURCE: LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Posted on Aug 18, 2009
  • 5 Answers
SOURCE: LG Dryer Sensor
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again
Posted on Jan 17, 2010
I have an LG Electric Dryer Model No. DLEO332W. It runs fine on ultra low or low heat, but if in the middle of the cycle I turn it to medium, medium high or high heat it cuts off.
There is a hi-temperature limit switch in the heating area that may be the issue. It can be manually reset but hard to get to. Top off, control panel off, front off.
Dec 03, 2017 | LG Dryers
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
How do get the drum out of dryer mo,dle2350
Their is videos on youtube that show how to disasemble lg dryer like this one:
http://www.youtube.com/watch?v=Sy_ZK5f-WS8
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2013 | LG DLE2350 Electric Dryers
Dryer beeps while drying
Most likely you have an excess of lint hampering air flow from the dryer. Vacuum out lint filter area, gently remove aluminum exhaust duct behind dryer and make sure it is clear and debris free. Also check exhaust duct port on back of dryer and that the vent going out of your house is clean and not stuck closed or clogged.
Jan 04, 2013 | LG DLE2101 Electric Dryer
Hello I have a 55" phillips 55pp9363h/17.When I tried to turn my tv on it won't turn on and the TV is making a high pitch beeping sound what might I do to fix this.I was just watching the TV 20 min ago.It...
The high pitched sound means there is a short on the Deflection board which is the middle board. Most likely it is a shorted transistor or capacitor on that board. Not a do it yourself fix. Someone needs to get the chassis into the service position and check for shorted parts on that board.
Let me know if you have questions.
SD TECH
Oct 02, 2010 | Philips 55P8241 55" Rear Projection...
Dryer works but makes high pitch noise
This probally the idler pulley, drum rollers, or a bearing hard to say until you take it apart and take a look. There is a good video on checking and replacing these parts at www.appliancehelponline.com/servicemanual.html
Hope this helps
Mar 21, 2010 | Dryers
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
LG DLE2350 Electric Dryers Logo
137 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
