Question about Cycling
Instruction manual for bollinger magnetic upright bike no.20320
INSTRUCTIONS on Using Vaseline and hairdryer heat to help create a better seal on Kenmore upright manual defrost Freezer gasket??
cleaning the gasket first is a must . warm soapy water .then check the seal gasket with a magnet .before greasing it with vaseline,unless this unit is OLDer than I am it is a magnetic seal but they do split and need replacing .
Oct 17, 2015 | Kenmore Freezers
No tension on proform 215 csx upright bike
tention belt or spring is broken. buy a new bike its not worth fixing.
Jul 24, 2013 | Cars & Trucks
I need a parts manual for a Rex Titan 920 exercise bike. Can anyone help me please
I have an assembly/instruction manual for a rex titan ac-920 magnetic bike that also has a list of parts in it. It belongs with the unit I own but I could photo-copy it and email to you.
Sep 01, 2012 | Exercise & Fitness
No resistance
1) adjust the bolts with the magnet very well, the magnet is the key for resistance.
2) test the magnet with the magnet from your refrigerator for atraction or repulsion , and replace it.
God bless you
Jun 24, 2012 | Schwinn 140 Upright Bike
Schwinn 150 is hard to pedal how do I adjust the tension
LUBE the pedal, Retight the bolts with some wrench.
2) The tension adjust the magnet with the bolts, if there are loose retight the magnet. Test the magenet with the magnet refrigerator for to repell or attracted, change if necessary.
sincerely. God bless you
May 05, 2012 | Schwinn 150 Upright Bike
I was given a scwhinn magnetic bike trainer for a physically disabled youngster. She is unable to ride her bike - but could use it to build up her leg muscles. Please help me locate the user manual.
Please check below page:
http://www.livestrong.com/article/394319-schwinn-bike-trainer-instructions/
and
http://www.livestrong.com/article/77912-use-schwinn-bike-trainer/
Mar 31, 2011 | Cycling
Electronics malfunctioning on stationary bike
Something is obviously wrong with the electronics, and unless you find an electronics hobbyist who is willing and able to fix it you would need a new unit. To find out whether a replacement is available contact Bollinger (which apparently no longer makes exercise bikes): http://www.bollingerfitness.com/contact.html
May 28, 2017 | Cycling
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
Looking for a manual on Photosmart 320. Yhanks
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PHOTOSMART%20320-_P
On the right side of the screen, select the one that you want.
Jan 21, 2009 | HP Photosmart 320 Digital Camera
Cycling Logo
74 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
