Question about ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2 Motherboard
Hp a6123w has no display
Electrical failure, changed power supply and now computer "starts" up; cpu fans turn on, hard drive is spinning, no beeps, but stilll no display.
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 18, 2013
Inspiron m5030 cpu fan start working but stop working in a few seconds
Step 1:
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
Feb 10, 2013 | Dell Inspiron M5030 Laptop
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
I have a computer that would do nothing when turned on, including giving no beep codes. Everything seems to be getting power - the CD drive, CPU fan, and hard drive all start spinning. I disconnected...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 05, 2010 | Acer Computers & Internet
Green light on power supply flashes rapidly when I plug the computer in. Computer will not power up at all (no cooling fans start, no lights illuminate and no beeps come from the unit). When the power...
if the cooling fan on your PSU power supply unit does'nt spin when you start your PSU is faulty if it does then
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 21, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Hp a305w will not turn on.
Remove the side-panel.
Press the POWER button.
Does the fan inside the power-supply start to spin?
Does the fan on top of the CPU start to spin?
Is there any lamp on the motherboard that lights up?
Is there any noise (from disk-drive, floppy-drive, CD-drive) ?
If not, take your computer to a computer store, and get them to replace the power-supply. Hint: the smaller the computer-store, the more-likely that they will install for FREE, if you BUY from them.
Aug 09, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
I have a Lenovo A61 Thinkcentre that is about one year old. I am now hearing a fairly loud noise that comes and goes. When the system starts, the noise appears and lasts 10 - 20 minutes, then disappears....
Ok it still sounds like an fan. look for fans, one in power supply, one on cpu, one in case(frount or back), one on video card. before you start from cold unplug the fans that you can. and stop the one in power supply. then if there is no nosie you have to start pluging them back in till you hear the noise. **NOTE!!** don't run it long without fans!!( 40 secs) is long enough..
Feb 26, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
COMPAQ PRESARIO S5200NX WON'T START - Press start button, led's light up for about 5 seconds - hard drive starts to spin, then led's go off and every thing shuts down. Power supply is ok (swapped power...
Hi:
Since you swapped the power supply already, and have disconnected the DVD, CD, and floppy, that leaves the hard drive and motherboard!
Look the motherboard over, and see if there are any capacitors that are bulging or leaking out on the tops.
Is the inside of the computer very dusty? Check and make sure when you power up the tower, that the cpu fan is spinning up.
Your CPU could be overheating, so removing the Heatsink fan and re applying thermal paste is an option too
If it is, try resetting the CMOS on the motherboard, or pulling the CMOS battery for a minite.
Do you get anything to display on the screen?
If you have more than one stick of memory, take out one of the sticks if possibleif possible.
Nov 06, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Jan 18, 2009 | Acer Aspire T135 PC Desktop
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
On powering on'the screen remains black and the ethernet plug is flickering. no sound from the hard drive
the hard drive could have failed..Try a hard start to see if it will react. Do you get any beeps?? a warning beep or beeps may indicate a hard drive failure. Try to get into C-Mode set up. click alt/cntrl/del as you turn on the set.or alt/cntrl F10. Hard drive failures can happen if ther is to much written to the drive or just a plain 'Crash'.
Oct 14, 2008 | HP Computers & Internet
ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2 Motherboard Logo
56 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
