Laptop not connecting to the Internet - Computers & Internet
    Genius:
  • 1,669 Answers
Try using a cable directly from the port on your computer to the router to see if the connection problem is with the wireless unit in your laptop.
Posted on Jan 17, 2013
  • mohammed Jan 17, 2013
    Hi I did that and it was working with the cable
(1) How do I connect to my internet with my
1.In order for you to connect to the internet through your wireless acer laptop, you should first prepare your laptop to accept wireless connections in order for you to set the proper settings. On you network configuration under the TCP/IP settings where you put the Ip address, you should set it to dynamic because when you connect to another network, the router should give you the ip address in order for you to connect to the internet.
2/ In order for you to charge your acer laptop, you should have a power adapter in which you connect it from your laptop going through a power source. And also you should have the correct Power Configuration in order for you to charge your laptop, you should set the right power schemes as Portable / Laptop.
Jan 20, 2010 | Acer Aspire One PC Notebook
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
How to connect internet my laptop through my mobile (ASUS P527)
Connect your mobile to Laptop by data cable. Ensure you have activated GPRS/Internet service from your providers & also installed settings for the same on mobile.
Then on mobile screen go to Programs>Internet Sharing; select PC connection - USB, Network connection- Internet & press CONNECT. After some seconds you will see laptop is connected to internet.
Aug 11, 2009 | ASUS P527 Smartphone
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Router won't connect to the internet
I managed to figure it out. I had to clone the MAC address to get the router to connect to the Internet.
I still have another problem though, my laptop still won't connect to the router. I'm using Vista, is this a possible network adapter issue? My laptop is fine at connecting to other wireless networks round my friend's houses/libraries...
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Have connected the wireless router,I am receiving internet to laptop but now internet is lost from pc. Connection has been installed correctly i think.
you should make a connection from your PC to your router then connect your laptop to your PC's internet connection... you will need 2 dongles 1 in your PC and 1 in your laptop (unless you have it built in). get the connection on the PC first then find the connection from your laptop to your PC
Aug 21, 2008 | Computers & Internet
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
THE internet is coming up internet explorer can not be connected, when it's wireless. we can plug it in and then the internet comes up.
you have to configure your wireless modem (wep/wpa) so that your laptop can connect to the internet. the reason why you cannot connect in the internet thru wireless is that the connection between the modem and the laptop has not been established. so, try to establish the connection between your laptop and the modem.
Apr 01, 2008 | Computers & Internet
How do I hookup ps3 using wireless laptop
I'm assuming here that you mean that you want to connect your ps3 to the internet through a windows laptop connected to the internet wirelessly, correct me if i'm wrong...
  1. connect an ethernet cable into your ps3 and the other end into your laptop
  2. Connect to the internet on your laptop
  3. go to control panel on the laptop
  4. go to network connections
  5. select "Local area connetion" and "wireless network connection"
  6. right click on one of them while they're selected
  7. click bridge connections
your ps3 should now act as if it was directly connected to the internet
Feb 16, 2008 | Video Game Consoles & Games
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
