Question about Kwikset Professional Door Lock installation Kit
Doorknob fell off and wont fit back on - Kwikset Professional Door Lock installation Kit
  • 3,904 Answers
The post that it fits onto has a specific shape (it will only fit on one way). Actually there are two that need to line up if I remember right.
Posted on Jan 21, 2013
Iwas wanting to know if i can repair the shift cable myself instead of buying a new one?.... cable just snapped and gear shifter just went limp.. please help.
unless the adjuster fell of then you cannot repair the cable
if it snapped then it was need of a replacement one anyway
Apr 20, 2015 | Cars & Trucks
Cifial doorknob
I never seen a doorknob on a laptop before, I would love it if you post a picture.
Aug 26, 2014 | Computers & Internet
Cifial doorknob
You could use a needle.
Heater control valve located 1993 mercedes 190
Start simple, replace the dial as they often break on the back and wont turn the actuator when you turn the dial (like a broken doorknob). If its still a problem, then it gets complicated as you'd need to dig into the dash.
Mar 02, 2014 | Cars & Trucks
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Pulled of doorknob, all the peices fell out and now i cant put it back together
If this is an inside door from an old house, just take another one apart very slowly to see how the pieces fit. If this is an an outside door from a newer house, you might want to just buy a new lockset and follow the directions carefully. I assume you took it apart because it wasn't working anyway.
Jan 04, 2010 | Top Knobs M826 Door Pull
The key still goes easily into the doorknob
can be easy as wd-40 squirt of oil. try that first... then on to more drastic measures
Dec 13, 2009 | Schlage BE365-CAM BE365CAM620 Antique...
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
The knob is broken
youve probably solved the problem by now but i would use a spanner or molegrips on the spindle to turn it, fitting a new one would have fitting instructions included.
Sep 28, 2008 | Amerock 3 Ring Knobs - BP1586
Kwikset Professional Door Lock installation Kit Logo
79 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
