Question about ASUS Computers & Internet
Have had the ASUS K55A-Rh15N13 for about three weeks. Has been running great. Just turned it on and have a blank screen. What is next?
Getting a blank screen. What is next?????
    New Friend:
Remove battery and power lead for 30 seconds, then plug both back and start up again.
If you still have the same problem, please let us know if any lights (power, hard disk activity) show when you try and start the laptop.
Posted on Jan 17, 2013
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: how to activate bluetooth on asus k55a
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Posted on Dec 08, 2012
bronk50
  • 27725 Answers
SOURCE: Asus k55a will not recognize my network
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop keyboard it should have a key something like (((.))) press it on
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required.
If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Posted on Nov 27, 2012
K55A Asus will not boot and f keys dont work?
Windows 7 and 8 require different keystrokes to boot into Safe Mode, which is your best bet to get help from Windows to diagnose and fix operating system booting errors. Holding down or tapping just the F8 key, the time-honoured method to get into Safe Mode, does not work with Windows 8. Here's a link that explains several ways to get into Safe Mode in Windows 8.
Knowledge Base
Dec 31, 2017 | ASUS Computers & Internet
Asus k55a will not turn on. Power light comes on, fan comes on. No hard drive noise or any other light. Running windows 8.1
Take it back to where you bought it and ask them to check the Power Pak. But it sounds like the Hard drive has bit the dust.
Feb 02, 2015 | ASUS Computers & Internet
ASUS K55A won't boot from OS installation on C: Drive. HDD does not show on BIOs boot.
try re seating the drive and your ram. if it does not show then your hard drive is bad.
Dec 28, 2014 | ASUS K55a 15.6-Inch Laptop Black Intel...
"k55A" dc jack replacement
Hello Kenneth,
The dc jack replacement cable connects from the white connector to system board and the connector where you connect the adapter lay on the edge of board usuallyc6c10d03-2117-4a84-8cc2-a16171601653.jpg
I like to use a litte bit of super glue to keep it held in place on the board.
Gotta remove some components to access it .
Mar 12, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
Asus k55a-rbr6 Cd Drive not recognized in Devices and Printers, will not run any CD.
The Asus K55A-RBR6 optical drive uses the Windows built-in driver. The drive may have failed or it could have a power or cable issue. To check for a power issue, try ejecting the optical drive by pushing the disc tray into the computer. If the drive tray ejects and retracts, it has power.
First, go to the Device Manager and check if there are any driver issues identified by Windows. (Click Start > Control Panel (in the right hand column. Click on either System and Security > System or Hardware and Devices and then select the Device Manager. Expand the section for DVD/CD-ROM drives and look for a yellow triangle with an exclamation point or a red triangle with an x. Try to uninstall the driver and then reboot the machine. Windows will try to restore the driver. (You should alsocheck Windows Update for any optional drivers. Start > Control Panel > System > Windows Update.)
Check that you have installed the latest available BIOS upgrade (407), from http://www.asus.com/Notebooks_Ultrabooks/K55A/#support .
The laptop uses a SATA slimline internal optical drive. The drive needs a power connector from the internal power supply and a SATA cable connected to the motherboard. You can access these if you disassemble the laptop. You may want to try just replacing the drive (~$25 at many vendors). If the second drive doesn't work, then try replacing the SATA cable and make sure it's well seated at the motherboard and the optical drive. There aren't extra power cables in most laptops but you should check for damage. Alternatively, get an external USB optical drive to replace the internal drive.
I hope this helps.
Nov 15, 2013 | ASUS Computers & Internet
How to fix status 0xc0000185
Is this a status message or a STOP: on a blue screen, when you try to go to safe mode? Are all drivers up to date, and windows updated and patched?
Nov 08, 2013 | ASUS Notebook K55A-DB51 15.6inch Core...
Asus k55a screen freeze
This problem occurs due to multiple issues like:
You have disable graphic card
Outdated graphics drivers
Your system is overheating
Check whether the Fans are running properly
If problem still exists then use system optimizer like PCFresher to refresh PC.
Apr 22, 2013 | ASUS Computers & Internet
Computers & Internet Logo
1,082 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
